Started in to waxing the door on the pine clock tonight and I'm noticing something: The knots and growth rings (read: harder wood) is taking the wax and developing a nice sheen, while the softer material is just flat. I've never waxed pine - will it eventually develop an even sheen, or am I chasing my tail here?
>What you are seeing is exactly what you can expect it the wood has not been finished. The softer wood absorbs the wax and does not provide a hard surface for the wax.
>Sorry, Scott, but it's not going to get much better. A thinned coat of shellac (wash coat) before waxing would have been a better approach.
About the only idea I have has to do with the type of paste wax perhaps making a difference. I've seen some evidence in my own shop that suggests a wax like Briwax will buff to a greater sheen than one like Johnson's when used on soft unfinished wood. Even on the soft grain areas of pine, I think you'll see a difference after several applications and buffings. I think you'll also get better results using an electric random orbit buffer.
Your mileage may vary but I think the Briwax, while maybe not providing the exact look you're after, will come the closest at this point.
It sounds as you did not use enough shellac to fill in the pores of the pine sufficiently. I would remove wax already applied with naptha and steel wool, clean paper towels etc, sand, and re-apply shellac, enough coats for uniform gloss. Then apply more paste wax with steel wool. It'll be fine, and look mellow and burnished.
George
PS After you complete the naptha regimine, and sanding, there may be some residual wax on the surface/in the pores. Shellac will cover it with no problem.
