Identifying existing finish-lacquer or poly?
Richard Krieger
>I checked with archives and could not find answers. IF I know that the finish is either lacquer or poly, anyone know how to identify which one it is??
Thanks in advance.
RLK
Re: Identifying existing finish-lacquer or poly?
Alexander Grigoriev
>Wet it with acetone or lacquer thinner. If it softens, it's lacquer.
Richard Krieger
>Thanks for your reply.........Are you saying that acetone or lacquer thinner won't soften Polyurethane???
Howard Acheson
>Here is how you can identify the existing finish:
http://www.hardwoodlumberandmore.com/TipSheets/WhatIsThatFinish.html
David Yoho
>Once cured (and I'm sure yours is), poly is not affected by acetone or lacquer thinner.
David
Lacquer thinner the most amazing solvent.
Chris Knob
>Yes it will soften some polys ....eventually. It takes a while. The disolving of lacquer will be instant.
I've used lacquer thinner for so much more than thinning lacquer. It's the industrial cleaner of last resort when all other methods have failed. One of the dumbest thing I ever did was to throw some oil based stain soaked rags into the wash. The inside of the white wash drum was ruined. I tried everything...nothing worked until I wiped it with lacquer thinner. When I was done, it looked newer than new.
Richard Krieger
>The article was informative and helpful. Thanks for the reply.
Happy New Year !!
RLK
Re: Lacquer thinner the most amazing solvent.
Alexander Grigoriev
>But it contains the nastiest stuff you don't want to inhale.
easy
Bill Tindall, E.TN
>Lacquer will promptly soften and eventually dissolve in lacquer solvent or acetone. With either the finish will instantly get sticky.
Urethane varnish will never dissolve in anything. Aggressive solvents like methylene chloride will soften it.
