I just picked up a very old Cannedy-Otto Royal drill press - floor model, but the base is hopelessly small and I need to make a platform to bolt it to. Please post pics and descriptions of bases you folks folks have made. Thanks David
PS - I'm pretty tall so thicker solutions are fine.
I would think some 4x4's, half-lapped, to form a square (a square that you feel is the size needed to support the drill press) and then cover this 4x4 square with some sort of 2x material (perhaps SYP or oak), I would also put adjustable feet on the base to eliminate any deviations in your floor. Then bolt your drill press on top of it.
>I'm sorry I don't have any photos, but I have a 20" Delta drill press and not that I was worried about the size of the stand, but I wanted to be able to move it around every now and then. So I bought a Delta mobile base for a larger piece of equipment (large shaper?) that was being closed out at a local hardware store. Since this drill press weighs a couple hundred pounds or more I laminated three pieces of 3/4" baltic birch plywood together and cut them to fit the mobile base. I then bolted the drill press to the base using carriage bolts and it has worked great for a number of years now.
>When my shop burned down almost ten years ago, one of the things I saved (for whatever reason) was the cast iron base from one of my old drill presses. It is 21 1/2" in diameter, weighs 48 lbs. and is meant for a 2 3/4"-dia. column. It's been stored in an outdoor shed all this time so it's pretty rusted over, but a short encounter with a bead-blaster should take care of that. I don't know how you would remove the remains of the old steel column, but it's gotta be possible.
It's right here in eastern PA if you want to come pick it up. I really don't want to have to crate it or haul it anywhere. Let me know by e-mail if you're interested.
>Wow, that would make a great stand for a floor-mounted bench grinder. I have both a grinder and buffer on floor stands - made one from an I-beam.
I've removed embedded steel pipes sections similar to that by beating inwards around the edge with hammer and large punch/chisel until it caved in a bit.
>Years ago I had a couple of vise stands made using rear brake drums from a two ton truck as the base. A weldor should be able to put on a base plate to match your pedestal. The stand rolled around quite easily and the mass made it very stable.
>I just bolted my drill press to two reasonably long pressure treated 4 x 4s. It got it off the ground so I could sweep and vacuum. It also got it up a bit higher.
