Re: Was this due to blade deflection?
Rick Christopherson
>It is hard to say what caused your burning without knowing what blade you used. If it was a coarse ripping blade, then your feed rate was way too slow. However, the closeness of the minor saw marks and the spacing of the major saw marks, my guess is that you were using a fine tooth blade, and that will cause burning. Your blade height doesn't look too bad, but it could have been slightly higher, especially if it was a fine tooth blade.
As for the saw marks, you'll notice that they are periodic, with minor marks packed very close together, and the major marks occurring at regular intervals. What I can't tell from the picture without knowing the blade type, is whether the frequency relates to the blade rpm or not. If you used a ripping blade, the frequency is too far apart to be one revolution, but if it was a fine tooth blade, then it is one revolution.
If you were using a fine ATB blade, look for a tooth that has a chip in the top bevel. Also check the blade for flatness and your arbor flange for runout.
If you were using a ripping blade, then look for something that could set up harmonic vibration that would span more than just one revolution. If its a contractor's saw, check the motor and drive belt. The drive belt could have a hard pulley bend if it had been sitting for a long time without use.
