Does anyone have one of these Sears switches? *LINK*
North of the Border
>Craftsman Auto Switch
Sears item# 00924031000 Mfr. model# 24031
I received one of these and it says the switch should be plugged into a grounded wall socket. Has anyone had any experience using it on a grounded extension cord or power bar? Anyone with the electrical knowledge to shed some light on this? The power tools I intend to use with this switch is away from any wall socket and I find it a burden to move my machines in order to use the switch. Thanks. Merry Xmas.
>Yup. Great product and not just for the shop vac. They work for in an exrension cord because the ground carries through to ground etc. Naturally cord size and length have to be yada yada yada.
If you use your shop vac for fine dust pickup the dust will soon clog the filter. Usa a drywall bag.
Re: Does anyone have one of these Sears switches? *LINK*
>It will work, just make sure the cord is grounded and the conductors are #14 or larger if it is on a 15A circuit. The reason they specify wall outlet is usually to prevent people from using it on a long extension cord that is not rated for the full current the device can be used with.
I am assuming the block only has one set of pins on it for plugging into the receptacle.
Bill
>They make special bags for vacuums that are designed for the fine dust you get from sanding drywall. A normal bag or filter will clog almost immediately from the fine dust and the drywall bags will keep working. You can get them for shop vacs and the like at most places like the borg.
>As Galen mentioned, I would not use this product as it is advertised. ( it's ideal for use with table or radial saws and dust collection systems ) The problem is that tablesaws and dust collectors each generally draw alot of amps, and each should be run on seperate dedicated circuits.
