200+ woodworking book reviews
Pair of boxes, walnut birch flame tops
>Here is a pair of boxes I made for my cousin and here Significant Other. Quartersawn walnut sides and a birch crotch for the top, and the tops are bookmatched.
Re: Pair of boxes, walnut birch flame tops
And here is the inside of one.
Re: And here is the inside of one.
Darrin
>Barry,
You're boxes are absolutely beautiful. Keep up the great work.
Darrin
Ken Platt (granby, CT)
>Very nice, especially those tops. Did you mill that crotch yourself? I'm always hanging onto crotch pieces for just that reason, some are really extraordinary. Birch seems to be the most figured of the ones I find around here.
Ken
>I did mill the veneer for the tops. I have had the blank they came out of sitting in my shop for about three years. Hacked it down to size with a chain saw and let it dry. Used a 14" delta bandsaw with fire to saw them. and it was about 8 by 14". Bought a sheet of 1/8" (3mm) luan plywood as a substrate. Put straight grained walnut veneer (also made it myself) on the back side for balance. Don't have a vacuum system, so I clamped the sandwich between two calls made from a plastic laminate countertop sink cutout. Used yellow PVA. Getting just the right amount of glue so that it bonds but is not too wet is something of a judgement call. Clamped them for over an hour and then took them out to finish drying. Sometimes left them in the clamps over night, but the plastic laminate retard drying so effectively that squeeze out around the edges would still be wet. I sand the veneer before assembly by carpet taping it to a caul and running it through the Performax. The veneer is less than a 1/16". The panels are still less than a 1/4" after glue up.
And you are right, the birch is spectacular compared to the walnut in the other boxes, wish I had lots more. Amazing chatoyance (SP?).
