Vacuum Pump------WebKitFormBoundarywBm9fw7wGpC0+GF
David Haywood------WebKitFormBoundarywBm9fw7wGpC0+
>I am thinking about building/buying a vacuum chucking system. The main piece of the system that I can not build is the pump. I have looked at several websites comparing prices and read some of the info from various turners. Most say to get a rotary vane pump because it is the best for the money, ie cheapest. Is it the best? Or, is their something better, or is it fine for chucking?
------WebKitFormBoundarywBm9fw7wGpC0+GFg
Re: Vacuum Pump------WebKitFormBoundarywBm9fw7wGpC0+GF
Re: Vacuum Pump
Chuck W
>look for a good used rotary vane pump that will still pull a vacuum and is not worn out. Pumps like these egt used a lot until it wears out at which point it is replaced. Rebuild kits are available for most of the alcatel pumps if needed and are inexpensive. A good rotary vacuum pump have an ultimate pressure of between 10 and 100 mTorr
>Post your question on the Turning Forum for more answers. (Under MESSAFE BOARDS on left.)
I mad a vacuum chuck but I used a pump I had and don't know what type it is, It's a small Gast, but I don't know if it is a rotary vane.
I think the Joe Woodworker site has info on building one.
Its a good idea to put a reservoir in the line to give you time to stop the lathe if the pump stops.
Bill Howatt
>You can use almost anything but an issue is the pumping speed since the system will have some leakage in it - some species of wood or spalted wood will leak through the pores and then you have the interface, joints, etc.
I originally used the compressor from an old window air-conditioner unit and now I am using a very old dual-cylinder farm refrigeration compressor as a vacuum pump. The rotary vane pumps are very good as a rule but want to make sure the inlet line is well filtered since the vanes can be easily damaged from something sucked into the pump.
I can't really give you a pumping speed number so perhaps somebody else will. Normally the vacuum for this type of application gets expressed as inches of mercury (Hg). A perfect vacuum is about 30 inches of Hg or 760mm Hg in metric. For vacuum chucking a measured vacuum of over 20" is usually provides a pretty good hold. I often turn pieces on a 6" drum chuck with 10-15" without problem but getting below 10" is starting to push it with a 6" dia chuck. The larger the area of the workpiece under vacuum the less vacuum you need. The holding force in lbs is roughly 0.5 the inches of vacuum times the area in square inches.
Greg Burnard
>JoeWoodworker.com gives you a wealth of information and material sources to make your own vacuum pump. Good luck
