OT-DVD Players
Sawman
>OK, so I am postioning muself to get a combination DVD player/recorder and VCR after Christmas. But I have a question. What do they mean by"Progressive Scan"?
OT-DVD Players
Sawman
Re: OT-DVD Players
Jason Roehl in Lafayette, IN
>Progressive scan means that the whole picture is updated. The older standard is an interlaced picture, meaning that only half of the scan lines are updated with each frame. So, when you see a TV advertised as "1080i", that means it has 1080 lines of resolution, but only 540 of them are updated at a time. 1080p means that all 1080 lines are updated at a time. If you see a 60 after the p, that means this happens 60 times per second, a 120 after the p means 120 times a second (this is usually a function of the TV's processor interpolating and adding intermediate frames).
If you have HD, or think you will get it anytime in the near future, you want to have progressive scan or, even better, "upconverting". Even better would be to go with Blu-ray.
On a side note, I just saw in the last couple days that the last VHS tapes produced were just shipped--the format is dead, and it won't be long before you won't be able to buy blank tapes.
Jason
It has to do with how the image is refreshed
Steve Antonucci
>TV's can support interlaced images and prgressive images. Interlaced is every other line, progressive is each line in sequence.
Progressive is better. If you see HDTV things like 1080P, the P stands for Progressive... I in 1080i is interlaced.
Steve
Re: It has to do with how the image is refreshed
Sawman
>Thanks for your replies! The only reason I am going with the combo unit is we have a bunch of shows recorded on VHS and don't want to "forget" them.
Re: OT-DVD Players
Dave Paine
>The other replies explain about Interlacing vs Progressive scan.
I bought a DVD Recorder/Player/VHS machine two years ago. Still working.
I use re-writeable DVD's. Be aware they may not last for the hundreds of re-write claimed, and you will only find out after some program did not record.
My unit is a Samsung model. It has a delay during start up. This confuses my wife who then starts changing sources, audio etc. and normally ends up blaming me for messing up the settings.
The recording on DVD is very good. I have not used the VHS part.
My unit "upverts" to 1080i, which matches the present TV. The "upvert" from the DVD recording or DVD playback of commericlal DVD is very good. The "upvert" of the cable TV is too soft. This is why I have to switch between DVD and TV. The TV's tuner does a better job at displaying normal cable TV signal.
Whatever you buy, find out if cables are included. Frequently only the old RCA style cable is included, if any.
Also "older" TV's like mine (about 4 -5 years old) have DVI connector for HD input. Latest standard is HDMI. If your recorder has HDMI cable, it will be with this connection at both ends. You can find HDMI to DVI, which is what I had to purchase for my setup.
Identifying cables and reason for technology *LINK*
>Technology only exists to confuse us. It is not to make us more productive, or to make the world a better place. It is simply here to confuse us.
It used to be that computers were all that was needed to confuse people, but then they realized that they could confuse even more people by applyign technology to watching TV.
My job is to help people cope with technology :)
So here's a link that might help if you don't recognize a DMI cable from a HDMI cable, from a CABLE cable.
Happy Woodworking!
http://www.outerlimitsconsulting.com/support/ident
For all your cable needs...
>I've ordered from this place...very happy customer--quick shipping, great prices.
About those RCA cables
Tim Greif - West of Chicago
>My very simple DVD has both composite video (single yellow plug) and component video (red/green/blue plugs) outputs. The manual says to use the component connections for best quality. I've never been one to believe in the magic of the expensive "special" cables. I want to know if anyone can tell the difference between REAL color coded component video cables and simply using three normal A/V cables with RCA plugs to hook up the component video jacks. I'm feeding a 52" Samsung HD LCD and right now, the pic looks fine with the old-school composite video yellow jack connection. Is there really any reason to change?
They may work...
>...and evidently are in your case. The biggest jump in quality is the addition of more shielding, which even the cheapest color-coded component cables will have. I once had problems getting a digital coaxial connection to work because I was trying to use a cheap RCA cable I had laying around. I switched to a different, newer cable and it worked fine. Check my link in the post below for cheap, but quality cables--don't buy cables from the eBorgs. When it comes to digital signals, they either work or they don't, and you'll know. Once the signal quality drops below a certain threshold, it will become unusable, but you won't know the difference between just above that level and 100%.
Jason
Where's the link? hahaha! nm
Tom Dunlap
Well, I'll be... *LINK*
>I had named it, but forgot to put the link in, so it didn't show. Hadn't even noticed 'til now. Here it is:
Monoprice.com
Re: About those RCA cables
Bill Howatt
>It seems there are two issues here. One is whether or not component video connection is better than composite video and the other is the quality of cables.
Component video does offer a better connection than composite video. Real cheap cables, especially if they are long, can degrade the signal. Does this mean you need a $100 set of cables, no. You are less likely to notice degradation with composite video because its bandwidth is not as high to start with.
Now that I'm older and my eye aren't as sharp and my tri-focals need replacing, it doesn't really matter much anymore. This is why I don't bother getting a HD signal source for my large TV.
Bill
