THE WOODRAT IS BACK!
Any body Make wooden hinges?
>Does anyone have experience making wooden hinges? My son (and that means I get to help) is making a jewelry box for the GF and wants to make wooden hinges. Any advice or tutorials would be appreciated.
Re: Any body Make wooden hinges?
byron
>incra makes a templet and it comes in a kit with instructions. I
have one and used it on a jewerly box and it works good.
Byron
tek,brunswick
>Roy Underhil covers it in one of his books. I'll try to look up which book later.
I tried, but they wooden work
Clint Searl, at the base of Haycock Mtnc
Knuckle Joints For A Pembroke Table *LINK*
Frank Mutchler
>Hi, Barry. The link will take you to the download page on the WoodRat website. Once there, you will see a listing of 'Instructions In PDF Format'. Find the 'WoodRat Corner' (2nd from bottom) and click on its download trigger.
You'll now have a wr_corner.zip file which has a lot of neat tips & tricks for using the WoodRat. After you unzip it, open the first file, WR Corner 1-3.pdf. In it you will find a tutorial on making knuckle joints for a Pembroke table. Might be what you're looking for or something to get you headed in the right direction.
Here's Another Link  *LINK*
Frank Mutchler
Woodcraft's Tutorial
Keith Newton------WebKitFormBoundaryV6MZb+tiOpocz6
>Barry, If you can make finger joints, and I am sure you can, and have a metal hinge of about the size that you are wanting, you can use it for a drill guide for a wooden one which has the same spacing for the knuckles as your metal one.
Just clamp your metal hinge to your wooden part, then drill through where the pin goes. It should self center as it gets to the new finger between the metal knuckles. With a long aircraft drill, you should be able to shift the metal hinge/template along to new spaces as needed to continue along a long back.
Report back if you need help, although I may be away out mostly. K
Fred Davis
>Second the Incra , nearly foolproof
FredD
Check listings under WC Book Reviews
Al Kapocius
