One thing I have been interested in is making a chair/stool from a log. I understand all if the steps fairly well, but I have a question or two about the logs.
First, assume that I can get my hands on all the logs I want and more. How long will a log stay good for doing this type of work? I am assuming that it would have a "shelf life", but I am not quite sure what it might be.
Second, assume that I have more log than I can use before their "shelf life" has expired. Is there anything that I can do to extend the "shelf life"?
Thanks for the answers, I am getting set up to do some chair/stool making, and this is one answer that I have not been able to find in a book yet.
>"One thing I have been interested in is making a chair/stool from a log. I understand all if the steps fairly well, but I have a question or two about the logs.
Thanks for the answers, I am getting set up to do some chair/stool making, and this is one answer that I have not been able to find in a book yet."
Drew Langsner has a nice book on chair making - "The Chairmaker's Workshop. I vaguely remember a section on stools, but I could be wrong. The other "bible" is Michael Dunbar's book on Windsor chairmaking.
Shelf life - a log's shelf life is fairly long. As it starts splitting (end checking) it will slowly start getting cracks along its length. Splitting is not good - unless intended. To prevent this, I usually leave log sections in damp sawdust. You can also coat or paint the ends (Anchor Seal as an example or roofing tar). I've had logs last over a year.
When I do "green" wood for legs, I rive (split) my leg blanks out and rough turn them. I wrap the sections that I drill for tenons and I put them in a "hot box" (temperature is ~120 degrees F or so) for a week. I then finish turning them.
If you can't split the log right away, Anchor Seal on the ends will slow/stop checking. Biggest concern with not splitting right away is bugs getting under bark. They will get into sap wood pretty quickly, but less concern with getting into heart wood. I try to split into quarters/eighths as soon as possible and split off bark/sap wood. These can air dry for weeks/months and still be fine for greenwoodworking since they retain quite a bit of moisture. They will keep longer in fall/winter than spring/summer. I find that air dry riven pieces will steam bend fine. For longer storage, I have kept oak logs (quarters/eighths as above) under water for a year or more. The outside gets pretty nasty, but it is only skin deep. The dark stain gets into end grain a little deeper, so you neeed extra length (to be cut away and discarded) if you do this. Oxalic acid (deck cleaner) can be used to remove stains.
>Thanks for the info guys. My dad has a farm with about a 30 to 40 acre woodlot on it. I know he would not mind me cutting a tree as long as it did not go to waste. That was my main concern. I have also found tree companies that are willing to give me logs, but they want to give me a whole load when they have one, not drive here for me to get a couple of logs. I can control how many loads I get, just not how many logs are in a load.
If I go with either of these solutions and need some help getting rid of any wood, then I will be sure to let people here know. We can arrange something on getting it to you.
>John Alexander wrote. "Make a chair from a tree" He's a good writer out of Baltimore, I believe, maybe has passed on now, but was a lawyer by trade, and a green chairbuilder by avocation. Got a lot of people started.
There was an article years back about storing green wood in water to keep it in that 'ready to work' stage. I have little space for such endeavors, but it looked really easy to accomplish. John did it on his urban lot where his home and shop were, IIRC.
Have fun with this. There's much that can be done nicely with these techniques.
>My old pal Don Weber was recently looking for logs in central Kentucky. He's only interested in a couple species for his stick chairs and other green wood projects, particularly clear, straight, white oak. He prefers elm for the seats. If you have either of those species up for grabs, he might be up for a road trip to VA. Let me know anytime and I can pass the info along to him.
Don is a modern-day bodger, as you will see from his website. He has been doing and teaching this kind of work for a long time, so I'll bet he could give us some advice on storing logs until he needs them. Seems to me he cuts the log into lengths that he needs for different chair parts, then he splits them and coats the ends with Anchorseal if he won't be using them soon enough to prevent end checking.
>Something like maple in the summer can begin to mold quickly while in the frozen winter it will last as long as its cold. The heartwood of oak and walnut will stay good for years and chestnut decades.
We had a program by famous chair maker Curtic Buchannan and he puts his riven stock in a freezer after splitting out the blanks.
>I store my chair wood in two 600 gallon tanks back of my shop. Not all woods can be stored under water. Of the four woods that I would use in chair making (Red Oak, White Oak, Ash, and Hickory) the first three can be kept underwater almost indefinitely. The Hickory will still rot under water. The Oaks and Ash will eventually loose the sapwood, but you usually don�t use that in chair making as it is wasted. The wood will turn dark and the Red Oak will get a more pungent smell. Great if you like the smell of Red Oak. When I relocated my tanks last year my water system was acting up and because of the drought my water had a much higher content of iron than normal. That reacted with the tannins in the Red Oak and I now have some nicely ebonized Red Oak It will get slimy after about 6 months under water but that hoses off. I have no problem with mosquitoes in the summer being attracted to the tanks. It appears that they don�t like the acid in the water.
