Need help with dial indicator
Jeff H. - Oregon
>Been snowed in the last few days so taking adavantage of being at home and giving my table saw a tune up.
Running into problems and I think it is the dial indicator but not sure.
The dial indicator was working fine and the results on arbor runout (0.002"), blade runout (0.005") and blade parallel to miter slot (0.003") were about what I expected. I used a magnetic base with the dial indicator.
The problem I encountered was when I moved to the fence to adjust parallel to the miter slot. I keep getting odd readings. I would zero out the indicator at the front of the fence. The gauge would dip to about -0.007 in the middle of the fence and then go to +0.003 at the back end of the fence. Moving the gauge back to the original position and it would be 0.003" off. I checked the fence face with my straight edge and it to be true. I went back and redid my original testing and now found the readings to be about 0.005" off from when I originally tested.
I have not dropped the dial indicator. This is a harbor frieght $14.99 special. Did I go too cheap? Is it operator error?
