Need air compressor help (direct vs. belt drive) ?
snyder1
>Hi guys - I need a compressor to run basic shop air tools & to spray with (my old compressor died). Can anyone with experience in the matter give a comparison of these two compressors & if it really is worth the extra couple hundred bucks to go with a belt drive ?
http://www.sears.com/shc/s/p_10153_12605_00916778000P?vName=Tools&cName=Mechanics+Tools&sName=Air+Compressors+%26+Inflators
vs.
Model EX8200 (this is the only twin cylinder 110 v compressor i've ever seen).
http://www.asedeals.com/maxus_commercial_industrial.html
Many thanks !
John (PS - I've spent hours searching the internet & can't find any really good end of year sales - if anyone knows of any sites I should be checking out, I'd appreciate the tip - thx again).
Re: Need air compressor help (direct vs. belt drive) ?
Re: Need air compressor help (direct vs. belt driv *LINK*
Dave Paine
>If you can only use 110V you will be limited.
The attached URL is an excellant summary of what to look for in an air compressor.
I used to have a 2HP 110V horizontal tank direct drive model. Gave it away when I upgraded to 3 HP 220V vertical tank, belt drive, single cylinder model.
After reading the summary in the URL, perhaps I should have looked for dual cylinder.
I would recommend oiled unit vs non-lubed since much quieter which would favour the Maxus link. I was surprised at the much lower noise level of my 220V unit vs the old 110V unit.
http://reviews.ebay.com/Air-compressors-electric-for-home-shops-A-primer_W0QQugidZ10000000002309894
I don't have a handle on what you want to do
Chris Knob
>Running air tools for what? Sanders, grinders, rotary tools...how often, how long?
Some basic guidelines.
Pancake direct drive nailers are for nail guns only. You might get away with using one for a little while to spray lacquer but you will fry it in short order. The same goes for larger dierct drive units with bigger tanks but the same old noisy aluminum housed oiless piston drive. They'll work for a while but they are destined for failure with spray equipment.
1 1/2 hp belt driven oil lubed compressors will keep up with all your nailing needs, most if not all of your spraying needs and none of your air power tool needs. A power pad ander will have it running almost constantly.
Air power tools require serious, 220V, dual stage compressors. Look to spend about 1K for a decent one.
