Flip side of a nickle.
steve mackay
>Going to try pistol grips for the BIL. Hes from Buffalo so would like the nickles inset into them. So far I think this would be better if the nickles were thinner. Seen it done on a lathe but might there be a way for the under-equiped to give it a try ? I do have the bench sander but not sure how to hang onto the coin.
Re: Flip side of a nickle.
Fred Davis
>It would be far easier for the average shop owner to inset the nickels flush , without trying a potentially frustrating and dangerous job of reducing the thickness.
At least that's the approach I would take.
FredD
Carpet tape
Jim Follette...Fayetteville,NY
>nickel to a piece of wood and use bench sander.
Justin Szeliga
>Just drill a shallow hole in the end of a piece of wood & set the nickel in it & sand away till the nickel is as thin as you want. That's what I'd try.
Peace
Justin
GalenV
>Not sure what model of pistol you are dealing with. Most of the pistols and revolvers I have the grips are thick enough you could use an unmodified nickle. Seems like it would be easier to drill through or at least deeper. I suppose a nickle is not going to work with about a 7/8" hole?
I always had a hard time matching the mounting hardware so if you got that worked out let me know what you used. Never could match the threaded insert or ever match a countersunk hole well.
If it happens to match a gun I have maybe you would take orders?
My zebra wood 45 auto grips I finally threw out since as ugly as the old parkerized devil.
Galen
Galen
I'm with Justin...
John in NM
>Drill a tight hole as deep as you want the nickle thick, maybe with a smaller through hole to pop it out with a little dowel. Then sand it down or grind with a dremel or the like. Might need a bit of super glue to tack it in, then soak in acetone to remove.
Make sure you post pics! (I've made lots of grips, never let in a coin though)
>I think Rockler (or someone) sells a Forstner bit for the various coins. I know they have one for quarters - and they probably have one for nickels. I'd just set the hole coin in. It is under 1/8". You may want to have a layer of clear epoxy on top of it.
Re: I'm with Justin...
>Justin and John have it. Glue it onto or into a block and sand away, either on the lathe or on a belt sander. Either way, work slowly with sharp sandpaper and a light touch. If you get heavy handed and get it too hot, the glue will turn loose.
You might be able to use some of your scrapers on this, but I woudln't expect it to work well. One catch and the coin goes flying.
LOL ! I DID measure the size . . .
steve mackay
>of a nickle for recon. The figure in inches makes pai look tame. Have'nt looked it up but I'd guess its the same as an obscure English coin everyone has forgotten. Since I've never held just a pair of grips in my hand I did'nt know they were thick enough to accept a coin . ? . sounds like I'm getting ahead of myself and borrowing trouble.
Custom drill bit/colored epoxy
Tom Dunlap
>Instead of buying a bit that you might only use once get a spade bit and a micrometer. File the bit down to the size you need.
Can color be added to epoxy? As I was typing I thought of an idea. It might not look good in this application but if the slug was let into a larger hole and colored epoxy, even with glitter in it, could be used as a surround. Someone must have tried this already.
Re: LeeValley.
Alexander Grigoriev
>As luck gets it, Lee Valley has Forstner bits for all coin sizes now. Saw it today in "what's new" list.
Be careful grinding
Lee Schierer - McKean, PA
>Nickels as you probably know are not made of steel and will tend to clog grinding wheels. Nickels are an alloy of nickel and copper (monel).
Lee
