FWW video showing kickback and riving knife *LINK*
North of the Border
KIck Back
North of the Border
KIck Back
Re: FWW video showing kickback and riving knife
Stephen Kirk
>Nice video. Table saw safety is something it's easy to take for granted even if you've used on a lot. I don't have a riving knife but I always use my Micro Jig splitter when I'm ripping.
I used to think I was safe when just crosscutting but I guess even during that a piece could rotate in and kick back.
Riving Knife
Gil Jones
>Where might one acquire a riving knife to fit on a 10" Delta Unisaw?
You can't
Dan Donaldson
>The design of the trunnions is different on a saw that uses a riving knife. The riving knife has to be fastened such that it moves with the blade, so it is not just a matter of adding one.
I'd love one that's easily removeable
Chris Knob
>Easy on/easy off saw blade protectors for the table saw have been a fantasy for any years. As a woodworker who has left fingertips on the shop floor and who has staggered away from the saw with a narrow, foot long, kicked back strip of wood stuck in my bicep, this is a priority. I have used removeable zero clearance inserts with and without a mounted splitter glued to the insert as my most easily switchd out option but it doesn't travel so a compromise height has to be chosen.
With a Riving knife can you.......
>Cut a dado or slot without removing it? It seems to me that if it were just below the top of the blade, you could. That would eliminate many cases where you would have to remove it.
Ed Wozniak, Buffalo, NY
>That is a nice video but the demonstration of kickback does not do justice to show how bad kickback can be. It shows the Styrofoam almost gently flying back. I once saw a demonstration of kickback at a woodworkers show and it was terrifying! The demo in the video almost makes one think why bother.
When your Fear trumps Common Sense
Keith Newton------WebKitFormBoundaryV6MZb+tiOpocz6
>I have watched that video before, and while it may show how the splitter can prevent kickback, even if you are using bad technique. They set it up by showing bad technique, without explaining proper feeding, by balancing hand position against the resistance of blade, fence, and saw top.
Too much fear of loosing fingers might be the worse cause of kickback. If your normal practice is to feed panels with your fingers all of the way over near the fence, then all of the resistance is out toward the blade side, which is the cause for the rotation which will induce the problem.
It seems to me that they should spend a bit more effort showing how to keep the work in balance where there isn't as much tendency for there to be a problem.
Rather than just using a feed stick over against the fence. How much effort would it take to also show the work with the hands half the distance between the blade and fence.
If the purpose is to sell riving knives, this may be fine. But if there someone is new to the TS, seeing an instructor feeding a panel like that is teaching unsafe techniques.
I think it would be a good idea to follow up showing proper hand position, with or without the riving knife.
Re: With a Riving knife can you.......
Brian in Sandusky, OH
>On my SawStop -
With a slot and the regular blade, yes, you do not have to remove the riving knive. The knive sits below the uppermost part of the blade.
However, with a dado, you do have to remove it. The dado is 8", rather than the 10" blade.
And someone mentioned that they wish that there was one that was easy to remove. The SawStop is. Just turn a handle, and take it out.
North of the Border
>My belief is the video was intended to show a kick back action - not all possible kinds of kick back outcomes - and in such case, the use of a softer material would be in order. Of course, the main intent of the video wasn't to illustrate how a kick back was like but rather how a riving knife was meant to prevent a kickback. I do know there exist some vids that vividly show some violent kickbacks in a controlled setting.
Many woodworkers (me included) never experience any kickbacks in person - by the way, I never push anything through a tablesaw blade that's less than 1 foot wide and I never use a push stick which in my view is not a safe tool to use. 80% of my cuts are done with the help of a push block or push shoe. But we all can benefit from such improvement. Hopefully one day, riving knives and sawstops will become standard features in tabelsaw as airbags, ABS (and soon ESC) are in our cars. I was surprised to learn that we fell such behind in the use of riving knives as compared to our European folks.
Stephen Kirk
>I've seen it first hand, and that's why I bother. Maybe we need a setup of an operator behind a safety shield doing it with some nice chunk of wood. See how far they can embed it in the wall behind them. Maybe get those guys from the TimeWarp show to film it in super slow-mo to see what really happens.
I agree with the post above that good technique is also key to making safe cuts.
As safe and accurate as a good table saw sled is you'd think you'd see more on the market, too.
Alexander Grigoriev
>"I was surprised to learn that we fell such behind in the use of riving knives as compared to our European folks."
No surprise. It's not the first time when profits trump safety concerns. Metrolink/Amtrak operated without automatic brakes because of that, which caused a horrible accident recently. Even in Russia, railroads have had automatic safety systems that would prevent such a disaster.
There are two ways you can force the manufacturers to introduce safety features: competition and government mandates. There was no competition.
