Powermatic Model 31A "out of box" review
Virgil
>Powermatic model 31A
Machine specs. 6� x 48� belt 12� disc. 110 v 1 � hp
Price after rebate 979.90 + tax
Our local Woodcraft store in Lexington KY had a sale a couple of weeks ago and I stopped in just to look but impulse took over and I bought a new PM belt sander. This machine replaces a mid 1970�s Delta machine which was only a belt sander.The store was offering 10% off with an additional 100.00 rebate from the manufacturer.
The machine had to be ordered which took 8 business days. The Woodcraft staff was very courteous throughout the entire transaction, notified me promptly when the machine was in and loaded the machine in the truck for me.
The machine was well packaged with no damage to the 2 boxes or scratches in the paint. One box contained the 1 pc stamped metal enclosed base with motor, cord etc. and the other the belt and disc combo. The door in the base for motor access has to banged on after the lever is loosened in order to open it. Assembly was easy and took around 1 hour. The threads on one hole for the dust collector adapter had to be cleaned up with the appropriate metric tap but other than that all the threaded holes were clean, lined up properly and the screws started easily.
The platen for the belt was visibly flat when checked with a straight edge as well as the table for the belt sander. Runout for the 12� disc was .004 and the table for the disc side had a .006 crown. I noticed a slight vibration when the machine was started and traced that to the 6� wide crowned pulley which drives the belt. Runout on this pulley was .012 on one end .014 on the other (in the opposite direction) which I think is a bit extreme. Runout on the top idler pulley was .001 on one end and .008 on the other. I plan to follow up with tech service on this issue. It flunks the nickel test. (Nickel does not stand on edge while the machine runs. In reality this is a sander and I don't know how valid this test is.) The leading edge of the belt platen had a very sharp edge and filing a .010 or so bevel seemed to reduced belt noise. (probably voided my warranty :-)
The design of the belt table tilt mechanism is such that I have only 7� of vertical working belt to use with the table compared to 10� on the old Delta. An initially smaller work surface but the table is removable (remove 2-12 mm socket head screws) which exposes the entire 14 �� platen. The belt sander can be rotated from the vertical working position to 45 deg and horizontal without by loosening a knob and retracting a spring loaded plunger.
Initially I am a bit disappointed in the smaller work surface when using the belt table. Time will tell if this is a real problem for me. I don�t look forward to removing the table although it is designed to be used in several positions.
