Cleaning Saw Blades
Cleaning Saw Blades
Cleaning Saw Blades
Rod Rentz
>I have been building my kitchen cabinets out of heart pine. I got lots of sap buildup and blade dulling. When I cleaned the blade I realized that it was the buildup and the blade was still relatively sharp. My question is about the method of cleaning the blade. I used a small, fine bristle wire brush (brass it think)and denatured alcohol. It took the sap off very quickly. As I have not heard of anyone using this method, I was wondering if the denatured alcohol may have an adverse effect on the carbide tips? Should I maybe wipe the blade with a light oil?
Re: Cleaning Saw Blades
You're shoveling the proverbial *&%$ against...
Chris Knob
>...the tide working with pine. I have found consumer grade oven cleaner works the best for pitch cleaning but there is lots of negative opinion about carbide degredation and this kind of cleaning. I'm not a chemist but 96% ethanol wouldn't seem to be too harsh a treatment.
As far as blade care goes...unless you have a beloved investment in a super quality $125 blade, I consider carbide tipped blades disposable on a once every 3-4 month cycle with regular duty use. Re-sharpening isn't really worth it. Buy a decent quality teflon coated combination blade, keep it clean, and bite the bullet 3 times a year and spend the $50 to get a new, sharp one one.
GalenV
>Denatured alcohol is used to clean the surface of steel and carbide when you epoxy the two together and similar if brazed. At least for metal lathe applications.
I use Simply Green to clean my saw blade and as long as I rinse and dry the blade have had no problems. I set the blade in a shallow pan and after a while brush it with a brass brush.
May not be the fastest cleaner but then I am not going anywhere in a hurry anyway. Retired.
Howard Norman
>Denatured alcohol isn't going to hurt the carbide on the blade in my opinion. I would think that something like a soak in Simple Green would be faster but I have never really done any experiments on the subject.
Ken Oakley-Sunny St. Cloud, Fla.
>I have used Simple Green to clean my blades and sanding belts since forever. Most of my belts are 5+years old and I have carbide blades from the early 1980's. I have them sharpened every couple of years for $8.00 per blade.
>I use either Simple Green and water or Dawn dish detergent and water. Both work well. I use an old toothbrush.
A friend of mine uses some sort of BBQ grill product on his blades - he claims it prevents pitch from sticking. As I don't have a grill, I've never tried it.
Simple Green is.......
Howard Acheson
>....not a good choice. The manufacturer recommends it not be used as it can damage the brazing holding the carbide to the plate. Simple Green makes a product that is formulated for cleaning metal and that would be the product to use.
It's probably OK to use as long as it is sprayed on and almost immediately brushed and rinsed off. Soaking should be avoided.
Meant to add....
Howard Acheson
>... that a couple of blade manufacturers recommend soaking in kerosene followed by brushing with a brass brush or a stiff synthetic bristled brush.
All purpose mixture
Clint Searl, at the base of Haycock Mtnc
>Mix equal parts Johnson's Baby Shampoo, Downey Fabric Softener, and Pantene Hair Conditioner and dilute 20 to 1 with ion free distilled water. Add a little Preparation H if you have the itch. Gauranteed to remove pitch, tar, and perspiration stains, but will cause your gums to recede if you brush your teeth with it.
Don't worry, be happy.
Clint
Resharpening still reasonable here...
John in NM
>I think I paid around $14/blade last time, local shop.
Jay St. Peter - SoMD
>I used to use simple green, but the wait and effort often made me use a dirty blade instead of bothering with it. Now I use the Empire cleaner. Just a couple minutes and I'm back in action. Good for the impatient, but fairly nasty stuff (although much less so than oven cleaner).
>I am stunned to learn that Simple Green is not recommended for cleaning blades. Whodathunkit?
I just cleaned my blade with cleaner made for the purpose by CMT (bought at WoodCraft for about $12). Boy did that work well. Its in a spray bottle. Sprayed it on waited about ten minutes and wiped it off with a paper towel. Another spritz on the teeth and a little careful wiping and the teeth look like new. Some stains on the plate thought. Come to think of it, I got on my hands, am I going to die? Before Christmas? Let me know because I am making gifts and If I am dieing, I can rearrange the list.
GalenV
>I see nothing on the Simply Green web site that would indicate it cannot be used. There is nothing showing up on the MSDS sheet unless some hidden chemical not listed. They do say for pots and pans so can be used on metal.
Maybe if you used it for a hundred years on the same carbide tipped blade?
I will continue to use it as I am the only one so far that has lost a tooth. Don't think the cleaner caused it, though, I probably breathed the fumes.
David Yoho
>Rod, I admit what I use is not very popular due to odor but I sill think it works fast at removing pitch and is as effective as anything else available, not to mention it's cheaper by far than the alternatives. I use plain old household ammonia and an old tooth brush.
I place my blade flat in my wash sink, pour on the ammonia, soak for 5 to 10 minutes, scrub teeth with brush, rinse and dry. The trick is getting around the ammonia smell. Luckily, I have a door very near to my sink that I open when needed.
I not aware that ammonia is harmful to the blade - at least I've not seen any problem with mine I've been using for many years. Woods like heat pine can really gum up a blade in short order. I can remove and clean my tablesaw blade and be back to work in under 10 minutes. Even with ammonia's pungent odor, I think it's safer than the oven cleaner-like products and works as well, if not better. The cost difference is a big factor too!
David
George Koch
>What ever your preferred solution for soaking the blades in ,I have found that the lid of a plastic 5 gal pail works best for the 10" blades. Shallow and just the diameter. George
Re: Cleaning Saw Blades *LINK*
Dave Paine
>Many different products available. Which one works best depends on the source of the build-up. Pine sap can be difficult if heat has caused it to harden. I use a product sold by Lee Valley.
I apply this on the blade, rub in using an old tooth brush, wait a few minutes then run under hot water to remove. Turn over for the other side.
Works for me. Cleaning makes a huge difference. Many people get blades sharpened before needed, and do not appreciate how much difference a simple cleaning makes.
http://www.leevalley.com/wood/page.aspx?c=2&p=30062&cat=1,41080,41165
Howard Acheson
>You can send a note to Simple Green and they will give you strong caution about using their standard Simple Green for cleaning carbide tooling.
The current edition of Fine Woodworking also has an article on carbide and carbide tools that talks about products and chemicals for cleaning tools.
And finally, here is a response from Freud on the subject.
QUOTE
Definitely avoid oven cleaner and other caustics. They attack the cobalt binder in the carbide and can lead to carbide failure (translates to tiny missiles of carbide at 100+ mph). Also, Freud and some other brands of blades have a tri-metal brazing foil that uses copper alloy for a cushioning layer. The copper can also be affected by these cleaners (translates to larger missiles of carbide). We recommend soaking overnight in kerosene in a vented container and using a stiff nylon bristle brush to clean. Teflon coated plates will clean up with a soapy cloth (except for the teeth as mentioned earlier). There are commercial blade cleaning products that are not caustic but we don't officially sanction them. The manufacturers of Simple Green recommend not using their product for carbide tool cleaning. Freud recommends using kerosene.
Charles M.
Freud, Inc.
CLOSE QUOTE
