Router on RAS
Router on RAS
Router on RAS
Jerry Gibbs
>Noticed in a Shop Shots article that a router mounted on a RAS was used. Is a mounting commercially available or has anyone made one? I don't have a use for an overhead router much, but it would be another nice option. Jerry Gibbs
Re: Router on RAS
Re: Router on RAS
Bill Houghton, sun/cold in Sebastopol, CA
>I've seen photos of router motors (e.g.,Porter-Cable 690 motors) added with built-up high-grade plywood "collars" bolted to the saw motor somehow.
Somewhere, I also saw a router base that bolted to the saw motor somehow - just can't remember what company.
If you happen to be in the San Francisco area, I've got an old radial arm saw that would be ideal for this purpose (the motor unit unbolts easily), and could run a 30" dado. E-mail me if you're interested.
Re: Router on RAS
Re: Router on RAS
Dave Paine
>I have an early 1980's vintage Sears RAS. Helped me do a lot of construction projects.
These days is only used for 90 deg cross cuts. Found out that moving the arm means not returning to the exact original location.
Better dust collection setup than my SCMS.
I have pondered about converting this to an overhead router/pin router.
I decided this is not practical for my use. Issues which came to my mind are a) flex in the arm, so a hard wood may not route consistently, b) if I needed to do a "plunge" cut, I would not be able to predict the depth without cutting, and then perhaps finding too deep, c) I still use the RAS for cross cutting.
If you can find an old RAS with burned out motor, give it a try.
Re: Router on RAS
Re: Router on RAS
Fred Davis
