Semi OT: Getting rid of the smell of Kerosene...
Glenn Madsen near San Francisco
>Where do I go for authoritative advice? Here, of course.
My daughter-in-law spilled kerosene lamp fuel in a box of laundry, and also the liner to my granddaughter's car seat. Three trips through the washing cycle, two with Formula 409, have so far failed to clear the strongish scent.
Any ideas? Weather here in the Bay Area is low 30's over night, and high 40's low 50's during the day. Should be clear Saturday through mid afternoon, rain coming... Airing it out outdoors may be a problem.
Re: Semi OT: Getting rid of the smell of Kerosene...
John E in SC
>Not sure if this will work with kerosene or not, but my wife usually has good luck at removing oily stuff by rubbing in a liberal coating of corn starch powder and letting it sit for awhile. The powder helps absorb any oil, and hopefully some of the smell.
Good luck,
John
Jerry Gibbs
>Good thing it was your daughter-in-law and not your son. Jerry Gibbs
>Corn starch or a similar adsorbent material should work reasonably well. Kitty litter, flour, activated charcoal all come to mind.
Baking soda/Dawn dish soap/wiki *LINK*
Tom Dunlap
>Baking soda seems to be a universal odor eater. Dredging the stuff with dry or maybe a solution of baking soda may work.
After seeing the critters being washed of the oil from the Exxon Valdez using Dawn dish soap I've been using it. Most of the time I thin it by at least a third because it's too hard to dispense in drops when that's all that's needed. In the shop I have a 60% thinned solution in a kids 'sippy cup'. I can shake out a bit on my hands when I need to wash up. Cheaper than Fast Orange and just as effective.
Masking the odor may work too according to one of the suggestions here...use cheap ground coffee. Unless the toddler doesn't like coffee on it's car seat :)
K'sene odor
Jesper, Denmark
Jesper, Denmark
>Your problem with the kerosine smell is that the smelly stuff are large complex molecules with a high boiling points.
Ventilation in a hot place, such as a vented dryer with a high drying cycle is your best bet as I see it.
BTW, you are not in the flammable range of kerosine concentrations after having washed it several times, so no risk there.
>Thanks, folks!
I think, given what she's tried so far, that Jesper's suggestion of the hot drier makes at least as much sense as anything else. We'll try that next.
being rid of odors
Bill Tindall, E.TN
>There are three ways to be rid of odors, but you have but one option for kerosene. You can chemically destroy some odors (for example skunk) or mask them, but you must remove this odor by volatilizing it out of whatever it has penetrated. Fibers like polyester are going to hold these odoriferous chemicals tenaciously.
I don't know if this will work but I would try putting the stuff in the dryer. The fact it smells means some of the chemical constituents of the kerosene are volatilizing. More heat will hasten the process of diffusing the odor chemicals to the fiber surface where they can then volatilize. I would expect dry cleaning would also work because the dry cleaning solvent is a good solvent for kerosene, while water is not.
Jason Roehl in Lafayette, IN
Careful with this one...
>A landlord we used to paint for had a duplex almost destroyed by a tenant who came home with chemicals on his clothing. He threw the clothes in the washer and hit the shower. When the fumes off the clothing hit the now-firing gas water heater, the exterior walls were pushed out a couple of inches...
Other than that, I'm with Bill--gentle warmth and ventilation.
Jason
Justin Szeliga
>Soap or detergent with hot water will remove it, it just will take alot of washing. Either heating it in air or washing hot with a detergent should get it out.
