OT Sheet metal Work
Sawman
>I need to do some ductwork work and was thinking about a tool to cut sheet metal and to do cut-outs in ductwork. I see there are nibbers and shears both electric. Is one preferable?
Thanks
OT Sheet metal Work
Sawman
Thanks
Re: OT Sheet metal Work
Chuck in ND
>What kind of cutouts ? in what type of duct ? retangular duct ? or round duct ?
Sawman
>Not round duct just the squareand rectangle. As for gauge noy sure it is whatever is coming off my furnace.
Chuck in ND
>Well if your looking to cut round holes in square and or rectangular ducting to branch off, I highly recommend one of these.
Re: OT Sheet metal Work *LINK*
Chuck in ND
>I supose you want to know what one of these in the last post is huh ? Sorry about that, here you go.
Malco hole cutter
Looks great, but......
>I couldn't find the price. (Did not spend long looking, but it was not obvious.
How many holes do you need to cut? Do you have good access? Can you get at the ducts to use such a tool? Do want to own such a tool?
When I was building houses, all the pros I ever saw used a hammer, screwdriver and some shears or tin snips. Aviation snips. You can buy them at the borgs or a supply house. Get left hand, right hand and straight cutting pairs. If you have good access you may only need one pair, either right hand (round holes) or straight (if you holes are square).
You take an old (slotted/straight) screwdriver and put the corner of the blade somewhere in the hole and pound it through the duct metal with the hammer. This opens a slot that allows you to insert the snips and start cutting. The advantage of this over the nibbler is that it does not drop lots of filings all over the place and other than pounding in the slot, its quiet. And you don't have an expensive single purpose tool left over.
There are snips that look like they are made of 3/16" plate steel and have been bent so that your hands stay above the work. A good pair is easier to use than the classic snips. If you are interested I will go look at mine and get the brand name.
Are you going to use "bought" takeoffs or make them out of elbows or duct?
Tom MacGregor
>I have five pairs of tinsnips - left, right, straight and left & right offset. I've been able to cut every shape I've ever needed to for ductwork. I'd want a full set of snips even if I had power sheetmetal tools. That said - nibblers are slower than shears but make more precise cuts, sharper corners and cause less distortion of the edges of the cut. I'd probably go for shears for ductwork or a nibbler for autobody work.
Re: Looks great, but......
Chuck in ND
>The HC1 is $50 and cuts a 2 inch to 12 inch range hole. The HC2 is $65 and cuts up to a 20" hole. For tight spots I use a Sioux 8800ES Tight Access Drill with it. I wouldn't consider what some do in the houseing trades to be standard practice, or even smart. This tool is well worth the money.
Second vote for the snips and screwdriver
Bill Houghton, sun/cold in Sebastopol, CA
>I wasn't in tin long, and it was YEARS ago, but I used exactly the same set of tools. All I ever needed, and I didn't even use straight snips - just right and left, of the pattern called "aviation" snips.
I also used a big (10") pair of conventional snips, but for the work described here, two aviation snips are fine.
DON'T get cheap ones - your hands will appreciate Wiss or other good quality snips.
And, to answer the question earlier in this thread, ducts are usually 28-32 gauge, a light gauge. Sheet metal gets thicker as the gauge number gets lower, and good aviation snips will cut 16 gauge, although you'll need to rest afterwards.
Snips will let you do the other cuts you need to do - cutting the ductwork to length, cutting rectangular holes, etc - that the hole cutter pictured earlier won't.
What I was taught when I started: as soon as you can, you want to hold up the waste sheet metal with your free hand. Don't, for obvious reasons, grip it tightly - you want the palm of your hand open, with your thumb and fingers kind of arching over, so you don't drive a sharp tin edge into your hand. Holding up the metal reduces the cutting effort dramatically. All this is something more easily shown than described...sometimes the Internet gets frustrating.
