200+ woodworking book reviews
ISO handles for serving tray/cutting board
ILYA ZAVORIN
>I am making my first cutting board. Well, it started out as a cutting board. Now I am thinking of turning it into a simple serving tray that can double as a cutting board. I'd like to add handles into the ends of the board. It's a bit large: 18.5" X 11.5" X 3/4" so the handles would have to be metal. I'd prefer handles that are pretty flat so that they end up level with the board. I searched in a couple of online places like Woodcraft but did not find anything. Can you recommend a store or a specific product?
By the way, is inserting metal handles into endgrain good idea? These handles are not just for decoration, the tray and whatever we put on it will be pretty heavy, and they'll need to hold.
Thanks much.
Re: ISO handles for serving tray/cutting board
Chuckb
>I like to choose one side to be a top, then run a long bevel, or a long cove along the bottom end of both end grain sides. Then you can slip your fingers under the ends and the board stays all wood.
>I tend to agree with Chuck. But, I round over the edges with a 1/4 or 3/8" radius so you can get your fingers under the board. I tend to make mine usable on both sides and sometimes put a "blood" groove around one side to designate it as the "Meat" side and the other side is for veggies. The handles would have to be sturdy, well attached, and not rust. Some people would use them to hang up the board, so they would have to be strong enough for that too. Don't think the "end grain" would be an issue over the width of a four inch handle.
Jim Dillon
>Ilya,
Couple of thoughts. Could you put some wooden legs on the bottom to lift it up enough to get a grip on the ends? Or some large large "rubber" bumpers (I forget what they are called) on the bottom side? If you did decide to use wooden legs, I would put some sort of rubber/silicone pad on the leg to keep the board from sliding. Given the size of your cutting board, could you cut elongated openings for your hands on each end with rounded over edges? You would have to keep the opening back far enough from the edge to maintain strength but it should be doable. I agree with the other posters that rounding over the outside edges would give the cutting board a better "feel". Lee Valley has a very nice selection of handles in their separate Hardware catalog, and likely online as well.
Jim
Lee Valley Hardware Catalog
Jim Toews - Walla Walla, WA
>These folks have, what seems to me, the best selection of hardware available. I've never been disappointed with anything I've ever ordered from them.
Thanks to everyone for the advice and link
ILYA Zavorin
