Accouterments for Rocking horse.
>Where do I start looking for leather to make the bridle and ears for the Rocking horse?
And, would you make the tail out of leather or yarn or what?
The horse if for a little girl.
Re: Accouterments for Rocking horse.
Kneale Brownson. Skiing now in Colorado
>I'd do the tail and mane from yarn, but my wife's a knitter and has a huge supply to pick from.
I'd look for leather from a shop that deals in leather goods and does repairs. In my community, there still is one of those. Otherwise, I'd visit the craft shops.
>Barry,
Do you have a Tandy Leather store in your area? If not, they sell online. Upholstry shops work with leather, as do shoe and some garment repair places. When I wanted a heavy-duty leather leash for a big german shepherd I went to a little alterations shop run by two wonderful little asian women who made me one almost instantly.
When I made mine, I cut a leather strip into three narrow strips and braided them together. I though leather would last longer around an active boy and in fact the tail is still intact after three active boys.
Barry's post made me think of...
Joe Pack
>Barry mentioned braiding, which made me think of the strips of leather used to re-lace baseball gloves. If you want to make a braided rein, these strips can be had a most any sporting goods store or shoe department.
Al Stokka - Cambridge, Iowa
>Good morning Barry,
Tandy Leather or The Leather Factory (aactually they are the same company) are very large suppliers of leather and related items. They have stores all over the country. In your area (about 15 miles away):
Tandy Leather #138 RICHMOND
Toll Free: 866-755-7090
Manager: Deb Jamieson
9129 Staple Mill Rd
Richmond, VA 23228
richmond@tandyleather.com
804-755-7090 fax: 804-755-7093
Al
And another question on the paint.......
>I am making the horse out of walnut. It's like the one John Jordan posted. I need some paint for the Eyes, seat and other parts. What would you use? Probably need black, white and red. Would you paint first and finish over it or the other way around? What would you use to avoid compatibility issue between the paint and the clear finish.
paint and leather
>Barry,
I used several coats of poly on the unpainted pine and painted over with enamel. If you had the time, a hand-rubbed Tru-oil gunstock finish would be more durable and look wonderful on walnut. You definitely want something non-toxic since a young child will tend to chew on everything and the mane will be right there in front of her little face.
FWIW, this is how I painted mine (picture). For the eye I made a stencil by cutting through masking tape then painted with a brush. I painted the seat and "hooves" as well.
BTW, leather shoelaces would also braid nicely for the tail but you have to think of a way to keep the end from unraveling. If you start with a strip of leather, say about 1/2-3/4" wide and slice it into three strips, you can leave an unsliced section an inch or so from one end to keep it together. What I did instead was hold them together with one of those little metal grommets you pound together - I cut small slits near one end of each strand to make a hole. Wrapping with sliver wire or tying with leather should also work - a spot of leather glue might be good. Glue the loose ends into a shallow slot cut under the seat. The tail is the thing that survived the longest on our little horse.
I cut shapes for the ears, folded the bottom rear edge over (shiny side out), and fastened with an upholstery tack. Horse's ears face forwards when attentive and stand erect (if they are folded back they are mad.) The ears eventually degraded and flopped over. Using thicker leather might make them stand up for another generation. Also, if you treat the leather initially and perhaps every few years with neatsfoot oil or a leather conditioner they should look great for the grandkids as well. I didn't know about this at the time.
Be sure to post a photo when you are done!
Ray Carson - Lawrenceville, NJ
>I made mine (the mane and tail) out of yarn and it's held up quite well. It flows real nicely when rocking. I posted the PICS here on WC. I'll see if I can get them from the archive.
Ray
Mane and tail- Rocking horse.
Greg
>I make the mane and tail from several pieces of 5/8 inch clean white nylon rope. Secure the ends to the horse and then unravel the rope to make a beautiful, full and wavy mane and tail.
