Woodworms and Rot
Woodworms and Rot
Woodworms and Rot
Ken Oakley-Sunny St. Cloud, Fla.
>A while back someone asked how to kill insects in wood. I just read the following in an email I received from an antique website I subscribe to. I do not know if it works or not.
"There are two inexpensive materials that kill rot and insects--borates (borax-boric acid mixture) and glycol, available as auto antifreeze/coolant (use propylene glycol, not ethylene glycol, which is a dangerous chemical that causes damage to the heart, liver and kidneys). Borates and glycol are water soluble, so brush the chemical on the affected area and let it soak in, or if you can, immerse the item in a bucket of the solution for a few minutes."
Re: Woodworms and Rot
Keith Newton------WebKitFormBoundaryV6MZb+tiOpocz6
>Ken, Dr Wengert over on woodweb says that the borates will only get them coming and going through the face, but doesn't penetrate the wood enough to kill what is inside.
His suggestion is to get the temperature up to, I think 140�, which will kill them.
If the wood is kept dry, then you don't have to worry about decay.
Some of you probably live in states where the termites require that houses have to be tarped, and gassed. If you are in one of those zones, Sometimes you can get the exterminator to just place a piece in the house, and it will get treated along with everything else.
Minimum of 130�.....140� would e better 8^ )
Scott in Eastern Iowa
