Fastening Base Molding
Stuart Johnson
>Is it better to fasten base molding to typical dry wall with staples or finishing nails? I'll be adding both base molding and shoe molding.
Stuart Johnson
Re: Fastening Base Molding
Jason Roehl in Lafayette, IN
>I've painted/stained many MILES of interior trim work, and probably installed a few miles also. The only time I've seen staples used is factory-applied casing on pre-hung doors--and I hate them because they're often left proud of the surface.
If you have pneumatic nailers, base is best put up with 16-ga, 2-2.5" brads, and shoe molding would get 18-ga 1.5" brads. If you're doing it by hand, use 8d finish nails for the base, pre-drilling holes for the nails, and 4d finish nails for the shoe molding.
Jason
Chuck in ND
>Finishing nails.
>Run a bead of PL polyurethane adhesive to stick it to the wall and minimize finish nails into the studs. If there's a tight dry fit, nails can almost be eliminated.
Clint
NickB in Eastern Mass.
>I normally use finishing (15ga, 'cos that's the nailer I have) for the base, and 18ga brads for shoe, base cap, etc. I have used 2" 18ga brads in closets and the like - less holding power, but how much stress does the baseboard take anyway?
2" nails for sure, though, and make sure you hit the studs or blocking.
Hope this helps,
Nick
Chris Friesen
>What happens when you want to remove glued-on moldings? The only time I've tried, it ripped out big chunks of drywall.
That's what joint compound's for
Re: Fastening Base Molding- thanks
Stuart Johnson
>Well I have a finish nailer but don't have a brad nailer. I guess I'll just have to suck it up and buy a new tool. Life is tough but we do what we have to do.
Joseph Mulherin, Sr
>Stuart, if there is a Harbor Freight store near you try them for the brad nailers. I bought two sizes and installed my baseboards nicely. Daub the nail holes left with some DAP and you will be very well satisfied.
