A real rip blade - should have done this long ago
Stephen Kirk
>The other week I got adventurous and picked up the Freud Glue Line Rip blade after getting a chance to look one over at a demo. I've been using a likely very dull 24T rip blade that was given to me. I put this Freud in, stuck some 3/4 red oak and went through it with ease. Left a super surface behind - I was quite surprised.
The blade is very nice and the moral of the story is - get good equipment as soon as you can. It's really worthwhile!
One question for anyone else who uses this blade - they say that it's for cuts up to 1". It's a 10" blade which means about a 3" cut height. I did some 1 1/2" pine with no issues? Is this a safety thing or does it just produce the best cut at 1"?
Re: A real rip blade - should have done this long ago
DizD
>I've had one for several years and use it mostly for 1" and under but occasionally up to two inch stock with no problems. The biggest issue is - keep it clean. The side tolerances are very close, so if you see residue on the teeth that means they need to be cleaned.
Bill Earl
>I've used mine on thicker stock with no problems. The cuts are not quite as glass-smooth, but are still very good. I suspect that it warps a little when it heats up.
Charlie Self
>IIRC, the glue line rip blade from Freud is a 30 tooth. It does a beautiful job. It WILL cut well over 1", but the cuts are less smooth, and in woods like cherry and maple you may get more burn marks. For those cuts, I'd suggest a top 24 tooth blade.
Chuck in ND
>Why didn't you just have the old blade resharpened if it was dull ? You didn't mention the the brand or kerf of the old blade either. In reality, it really doesn't tell me much as posted.
Stephen Kirk in Quakertown, PA
>I probably will send it out for sharpening and use it as a spare. Couldn't tell you who made it as it never had a name left on it.
Bill White
>Though I don't have the Freud ripper (mine's an Infinity), a REAL rip blade can be a delight to use. It also minimized the edge jointing time in my shop.
Bill
I agree
Charles M
>Charlie is correct. Ripping produces large curls of wood and so requires a large gullet to extract the chip efficiently. So rip blades have fewer teeth than crosscut blades to make space for these gullets. The number of teeth (and therefore the gullet size) and the low side clearance of the the LM74 GLR blade make it best for stock 1" and under. However, it can be used on thicker stock with the understanding that as the stock thickness increases, so does the potential for burning.
Charles M
Freud America, Inc.
