Planing end grain question?
>I have a lunch box planer. My son is making a cutting board of bamboo and palm. Wants it end grain. Anybody tried planing end grain? It will be about 2" thick and 12 by 16".
Re: Planing end grain question?
doug f, san clemente, ca
>Barry - I've never planed end grain, but it seems inherently unsafe to me. Too many ways to catch and send the chunk of wood out the wrong end of the planer.
Your best bet is wide belt sander; does a slick job and very safe.
Doug
>I agree with Doug. I think you would get too much tearout but I haven't tried it. I sanded the ones I made.
that is how I make them
Bill Tindall, E.TN
>You will need to glue a scarp on the exit side as the planer will chip out the end grain on that side as it leaves the planer. I glue up the end grain boards, add the backer strip and pane till smooth. After planing cut off the backer piece. It only needs to be 1/2" or so. Then I belt sand to burnish the surface and add some cooking oil to make it look good.
Fred Davis
>Since those two woody plants are a form of grass , it seem like they would make a very adsorbent cutting board.
FredD
Dick Coers
>bamboo and palm, oh my! On the odd chance that you could get it to plane, get ready to replace the knives. But I really don't think that stuff will end grain plane at all. I've only used them for making pens, and palm is a real challenge. Lots of thin CA glue to get good pens, and end grain pens are possible, but chip out always occurs.
Alex Yeilding
>A power planer is a poor choice for end grain. It is best cut with a very low angle of attack, such as with a low angle bevel-up plane, possibly even skewed to further reduce the angle of attack. I have also found that a coat of shellac, like SealCoat, gives the fibers a lot more "body" to stand up to the blade rather than being pushed into their neighbor. A power planer cuts at a very high angle of attack to minimize tear-out on difficult grain. But this makes it a poor choice for end-grain.
If I were building this, I would use a shooting board to perfect the end grain of the pieces before final glue-up, then make sure that glue-up was so perfect that only light sanding was needed subsequently. If you are not into hand tools, you could achieve much the same result with a perfectly set up power saw and a very sharp, good blade.
If you end up having to thickness after glue-up, and were confined to power tools, I'd suggest the wide belt sander or Bill Tindall's suggestion of a backer board, adding that each planer pass should be a VERY thin cut, and think about adding some body to the endgrain with shellac first (which might cut down on the over-absorbancy of these endgrains that others have mentioned).
