possible little winter project
>Here's a little project for winter to keep your toes warm - a fireplace bellows. I made the one pictured below at least 25 years ago and it's been VERY well used. (as you can see!) It was pretty quick to make and not particularly difficult. Might make a nice gift.
I used 4/4 pine for the body, red oak for the handles, and a piece of cocobolo for the nozzle. A metal tip would last longer if you tend to get close to the fire. I shaped the handles on a drum sander. The two body parts were glued then bored to accept the nozzle and make a channel for the air. I fastened the part that moves with a small hinge.
Inside, you need to add a flap of flexible something for a valve to let air in the vent holes on the intake stroke and seal to force it out the nozzle on exhaust. I used a stiff piece of leather, glued and tacked underneath the vent holes. To keep it from flopping too far and bending and becoming useless, I devised a small retainer from a bent piece of metal, but a couple of bent nails or a piece of plastic on the back should work as well. I gouged out the wood a bit for clearance for the valve but it probably is not needed since it really doesn't need to close flat. The flap valve only needs to open a few millimeters. I made a couple of narrow vent holes to prevent overly distorting the valve on the exhaust stroke.
I used leftover bellows cloth from rebuilding a player piano for around the body (glued and tacked), but a piece of flexible leather or even a piece of heavy denim should work fine. It has to be cut in an odd shape to fit - I made a template with the thing open. Another piece is needed to seal the hinge area.
We don't use a fireplace at this house, but I use this a lot with the woodburning stove to get the fire going when adding wood to hot coals.
