Help removing pen "dents" from table top?
Doug in Denver
>So I just completed a cherry dining room table. My brother was visting and wanted directions, so I grabbed a single sheet of paper and a BIC pen and drew a map. Of course now the map impression is in the table top. The top has no stain or dye, and has multiple coats of wipe on oil/poly mix - the General Finishes stuff Rockler sells.
The table has been finshed long enough - a month - that the top has started to turn darker. So if I sand out that section it will be forever lighter. I really don't want to start over on the whole top. Any tricks I can try? Steam would be great on bare wood, but I assume useless on finshed wood?? I had rubbed out the finish, so I can lightly sand and re-rub that spot, but I'm worried the dents, no matter how shallow, are deeper than the finish. Any suggestions?
