Sharpening Forrest Blade questions?
>Anyone had a Forrest WWII sharpened? At Forrest? Elsewhere? Were You happy? How long did it take? What did it cost?
Re: Sharpening Forrest Blade questions?
Paul Stone
>I always send it back to Forrest for the best results. It has been a while, but it seems like it cost around $30.00. They always replace a few teeth that are broken. When the blade is returned, which doesn't take long, it cuts just like when it was new.
Binen
>I also send mine back to Forrest for sharpening. The blade was a big investment and I want to protect my investment. When I figure the very best some other source can do is what I receive from Forrest every time, the decision is easy.
Binen
Jesse Cloud
>Most high end sharpeners use CNC equipment now and do an excellent job. I've always heard good things about Forrest's sharpening service, but there is probably someplace local that can do it for you, too. Ask a local cabinet shop who they use.
My guy in Albuquerque charges $16 for sharpening a 40 tooth blade. Replacing a tooth is $3. The blade is as good as new when I get it back.
BTW, he tells me that a lot of the blades hobbyists bring him really just need to be cleaned, not sharpened...
Dick Coers
>Definitely send it back to Forrest. I sent one to a major sharpening house in the Chicago area, definitely didn't cut the same. If you don't have the original packaging to send it in, bolt it to a piece of hardboard or 1/4 plywood before putting it in a cardboard box. The way packaging is handled these days, you might loose some carbide just in the shipping.
Same experience here
Dominic in Bucks County PA
>I've got nothing but good things to say about Forrest's sharpening service! They've sharpened my WWII blade 3 times so far and each time it's come back like brand new.
Robby Wright
>I have sent my WWII to Forrest a couple of times over the years and they do a great job for a decent price. The hitch: If you send the blade in, don't send it in a blade holder - you won't get teh holder back.
Robby W
San Marcos, CA
Tony - Memphis
>Well, I sent my Forrest blade in for sharpening and it cost me several thousand dollars. I was using a Delta CS and something was going weird with it. I was quite confident that I hadn't changed anything since I sent my balde in, so when I got it back and had an issue, I thought something was wrong with the blade. I called and got a quick response and sent it back and they called me back and said the blade was fine. Then I started messing with the saw and got frustrated (CS's are very hard to get adjusted - everything moves). Anyway, I had been daydreaming about buying a cabinet saw, I got a bonus, there was a sale... I ordered a new Forrest reg kerf for the new saw. Saved the old blade (it was thin kerf) with the fresh grind on it for someday. I gave the old saw to Habitat for Humanity - I doubt they needed a Forrest for what they will use the saw for. Anyway, that's my story and the point is that their service was very good even when I thought it was them, but it was really me. They didn't hesitate to take a look and they paid the return shipping.
Tony
Jim Dillon
>Barry,
Have had several Forrest blades sharpened by Forrest and was very pleased with the service. I thought the cost was very reasonable, and it took about a week; I live in Maryland. I plan to use them again, maybe later this winter. Dick's recommendation regarding the use of a piece of thin scrap plywood seems worthwhile especially if you don't have the original sturdy cardboard box the blade came in. Those teeth really are sharp and have a tendency to go through the side of an ordinary cardboard box. I remember using a piece of Tygon tubing (a clear plastic tubing available at the borg or local hardware store) split down the side and slipped over the teeth.
Jim
Mine is probably about due
Stephen Kirk
>And I intend to send mine back to Forrest. Still have the original box, too. Been over 2 years and I'm noticing it's taking a little more effort to make the cuts plus it's getting pretty dirty.
Thanks All and.....
>I took Jesse's advice and cleaned my blade. I used CMT cleaner I got at WoodCraft. (I had it on the shelf, so not cleaning the blade was just laziness on my part) The blade sure looks better and the amount of crap that came off it was amazing. I cleaned each tooth carefully. I have what appears to be one very minor chip and the blade still "looks" sharp and original, but I still suspect it time to go home for a touch up. The point it, Stephen, clean your blade. I have used Simple Green in the past and it worked well. Just lay the blade(s) in a pizza pan cover with cleaner and let them soak. The CMT stuff was a spray on that took about five minutes. Very worth it.
Re: Same experience here too
Brian in Brighton
As an almost 40 yr. user of Forrest blades.......
Art Silva
>all I can say is send them home to Forrest for refurbishing. To quote a movie title; "For a few dollars more" you get the absolute best, and if the cost to repair the blade outweighs the cost of replacement the old blade is worth $20. on trade.
Wow, you preceded Wally Kunkle!
I thought 36 -1/2 yrs. was close enough to brag.
Art Silva
>Mr Sawdust was still a bush back then.
Frank Orfanello
