>Now that I've got a nice TS that doesn't shift and shimmy the blade itself has drawn my attention. While I was nibbling ( I think thats a Norm-ism ) out a knotch I noticed the blade flexing side to side. Is this normal for all TS blades or is this one just a cheapo ? I'd hate to have a blade that was too much thicker. One would think I'd have noticed this phenomanon YEARS ago.
>Steve, this does happen with thin-kerf blades. I have several, and they all flex to some degree, though the Freud blades don't move much at all.I suspect that is due to the tensioning they give their blades. The two full-kerf blades I have don't bugdge unles I really use a lot of sideways force, but that is a sure recipe for kickback, something I don't have any interest in creating! Hope this helps.
>If your running a thin kerf blade , use stiffeners>
If your running a typical .125 kerf blade , and you still have flex. get a dial indicator, you more then likely have runout that could be caused by a burr on the arbor flange , poor machining at the saw manufacturer,rarely a bad blade , generally a cheap one , that was not tensioned at the time it was made , bad bearing installation that the arbor runs in, and if it only seems to flex when it is cutting , could be blade is not parallel to the miter slot or fence, this is a list of common causes not all by any means.
>I agree that thin-kerf blades in particular may benefit from stabilizers, but I think the flex you're seeing has to do with the fact that you're nibbling a groove. That means you're making a pass directly adjacent to a previous kerf. Any blade will have a tendency to lean (flex) toward the empty space.
Another cause of flexing is overheating, though that doesn't sound like a factor here. Overheating usually happens when you're ripping a bunch of thick stock, especially if the blade is getting dull or there is resin on the teeth or plate rubbing on the sides of the kerf and producing friction. Also, the harder the wood, the more work it requires to remove material, and the more heat is generated in the process.
Blades are tensioned to run straight in a particular speed range. Manufacturers use different specs but IIRC, 3,000 to 5,000 rpm is the middle of the range. The tensioning allows centrifugal force at that speed to straighten out the blade and make it run true. When you add heat to the equation, the outer rim of the blade -- especially on thin-kerf blades -- is the first to heat up. As the metal expands, it has nowhere to go, and the plate begins to warp. You can easily observe this visually. If it gets out of hand, I've seen blades warp enough to actually take a bite out of a standard throat plate. You need to turn of the saw and let things cool off if this happens. This is the downside of thin kerf blades, which were really designed to allow underpowered tablesaws to cut thicker stock with less feed resistance. If you're running a 3HP saw, you ought to be able to use a standard thickness plate without bogging down the motor except in the thickest and densest materials.
>It depends on the design of the stiffener. If it is ground concave on the side toward the blade you would actually be pushing the blade off center witht he stiffener. If the stiffener is ground flat on the side toward the blade, then one stiffener may help some.
>I have a full kerf WWII and a Duraline AT that I used to run with the Forrest stiffener. In a fit of not wanting to fuss with the stiffener, I left it off awhile ago to see what would happen. I no longer bother with the stiffener as I can't really see any difference. I have a Rockwell Contractor's Saw that recently had its bearings, pulleys and belt replaced and runs pretty smoothly.
>Yes, it will actually cause the blade to slightly dish. Like Robby Wright below, I have stopped using stiffeners and I really can't say things are really worse in practical terms without them.
>There is no reason to run a stiffener on a mstandard thickness saw plate which is specifically designed to resist the problems you encounter with thin kerf blades which as Ellis pointed out, were designed for underpowered machines being asked to perform like a 3 H.P. cabinet saw.
The hype issued by the thin kerf folk is "using one will save a lot of material" will flunk a math test in a typical shop enviroment.
On the the other hand sawmills that converted to huge band mills instantly saw a increase in usable lumber compared to the Paul Bunyan circle saws then in use with swaged teeth that took a 3/8ths bite kerf wise.
