Red Oak Flat Bow update
Matt Campbell
>Well, here is my update. The first bow was a bust. There was a patch of weird grain in it which popped up out when I tried doing some shaping with my newly purchased spokeshave and drawknife. So, I scrapped the initial bow and picked up some higher quality Red Oak the next day.
Here is a pic showing the taper of the bow. It is tapered from the handle section from 3/4" down to 3/8" at the tip. It's kinda hard to see in this photo.
Photobucket
A look at the rounded belly beginning to take shape.
Photobucket
Shaping with a spokeshave (this is after general roughing out with the drawknife).
Photobucket
Smoothing with the scraper. You apparently want to have a lot of pre-shaping done before you start tillering the bow because once you start tillering you remove more wood, effecting the tillering. Apparently if you have a lot of sanding and finishing to do at the end you can further affect the shape of the bow affecting overall shape - so I guess it's better to have it pretty smooth before you start.
Photobucket
Messier than I thought but still easier to clean up after than using a router in an apartment (been there, done that >:(
Photobucket
Black linen backing has been glued on, also the riser (part of handle), is a piece of mahogany, also glued on.
Photobucket
Bow with linen trimmed after it's dried. Next to it is the next bow I'm laying out.
Photobucket
Re: Red Oak Flat Bow update
Very interesting project
Bill Houghton, rain/sun/rain/sun in Sebastopol, CA
>Thanks for the pictures and discussion of what you're doing.
Nice work.
>But I still don't know if red oak is the proper wood. But then again, I'm not a bowyer.
Re: Nice work.
Matt Campbell
>Red Oak is one of the best woods for a first time bow. It's cheap, readily available, and has several other qualities that make it a good choice. Of course I'm no bowyer either but it's amazing how much you learn once you start reading. I'm learning everything somewhat by trial and error but also from experienced people who've made numerous bows. In fact I've already learned that three of the boards I selected are not going to be suitable for bows because of grain pattern causing likely failure. I'll need to take them back and exchange them but for now I'll settle for going back to the store tonight after work to sort through the pile and try to pick out some better stuff.
