Delta 14" Bandsaw
Delta 14" Bandsaw
Delta 14" Bandsaw
Mark in B'ham, AL
>Lowes has a new price on the Delta 14" bandsaw $369.00. I am considering a new saw and was wondering what you all thought about this saw? The reviews on Amazon are kinda mixed.
Re: Delta 14" Bandsaw
I suppose I should add what I would do with it.
Mark in B'ham, AL
>I mostly use my benchtop bandsaw for cutting out turning blanks and such. It is much too small for most of the free logs I have picked up, so I have actually been using my "reciprocating right arm" saw and my left arm is getting jealous. I know I'll want the riser blocks too, but budget restrictions abound. Mostly, I was wondering if the saw is constructed well and will hold up to some thick wood.
Thanks, Mark.
Re: I suppose I should add what I would do with it
Chuck in ND
>I don't know what model number your looking at but, most of the 14" bandsaws are import clones. The price tells me that it's probably a lowend 3/4 hp model. You may want something with more hp if your going to install a riser block on the saw someday.
Yep, it's a 3/4 hp.
Mark in B'ham, AL
Alexander Grigoriev
>For what it's worth, you can get Grizzly Ultimate 14" bandsaw for about same money, with 1HP motor and a fence included. Thoogh I would prefer block guides with my Grizzly rather than ballbearing ones.
Jesse Cloud
>I have that saw. It has served me well for several years and taken a lot of abuse. I do, however, lust after a bigger, more powerful saw for slicing veneer and laminations.
For instance, yesterday, I cut a bunch of 3/32 thick 6 inch high lams, they came out spot on, but I spent most of the morning fiddling and tuning to get there.
If you think you might add a riser block, don't invest in a lot of blades until you get the riser.
If you go with the Delta 14 get Luis Iturra's Iturra Designs catalog 888-722-7078. Its an education in itself and is the authority on tuning Delta 14 inchers.
Thanks y'all.
Mark in B'ham, AL
