Cherry wood darkening/ aging question
Grant in Iowa
>As with many of my projects, I have taken a LONG time to complete some cherry sidetables. I had the joinery cut, and the pieces held together with clamps for several months. Now I am trying to get them ready for finish, and I am finding that the wood has darkened or aged due to exposure to air and light. We did do a all the sanding necessary to smooth the wood in the last few days.
So now I have several areas where there are contrasts in the wood between light and dark such as where a clamp pad was or where another board was against the work. These are pretty obvious, and it seems it takes a lot of sanding to get rid of....more than I'd like to have to do.
The question is, do I now have to sand everything again, or maybe put the whole thing out in the sun for a day or so (if the weather permits), or is it safe to go ahead and finish them and let time heal the lighter areas? Some are very obvious such as where clamps held them together for months in my shop.
I plan to use waterlox as a finish, if that matters.
Any advice/ experience would be appreciated.
Regards,
Grant in Iowa<---in the midst of a Christmas rush.
Re: Cherry wood darkening/ aging question
Shadowing
Lee Schierer - McKean, PA
>When I make an item for folks out of cherry, I advise them not to cover it with anything for at least 2 years as the covering object can leave a shadow. Those shadows last for years and years. Unless you remove the shadows you have by sanding, they will show int eh finished project.
When you get them finished, don't set a lamp or anything on them that will stay put for any length of time for the first couple of years otherwise a "shadow" will develop. You can speed up the darkening process with cherry by sitting it out in the sun for several days, but even that won't complete the process completely.
Lee
No great solution
>Grant, as Lee said, it takes a long time, maybe years, for the color to even out, as both the light and dark areas continue to darken until they have reached what I would call that old cherry look -- dark reddish brown.
Selective staining isn't a good option either, because the unstained parts will continue to change color and will not look the same as the stained parts. You could stain the whole piece with a strong dye, but there goes the natural cherry look unless you're very good at color mixing.
Planing or sanding down the surface should do the trick, although the oxidation may run deeper than you think. I'd try it on a less conspicuous area and see how much material you have to remove before the color is uniform again.
No joy to the world here.
howard
>agree with Ellis, can you try running the tops through the planer, taking a light pass at first to see the results. If you have a drum sander this is another option. You can also try a scraper.
Karen
>You might try a solution of oxalic acid to bring it back to pre-darkened color. If you have a scrap piece, I'd experiment on that first. If it doesn't work, you're not out anything but about an hour's time.
Maybe lye on the lighter parts?
Ken Platt (granby, CT)
>I have the impression that lye accelerates the normal darkening process, so perhaps the area that you darken won't continue and end up darker than the rest?
Problem is, you won't know how successful you are for a few years.
Anyhow, just a thought. There've been threads here over the years on using lye to darken cherry, might be worth a look.
Ken
Re: Cherry wood darkening/ aging question *LINK*
Rusty Fenn
>Charles Neil would be the guy to ask
http://www.antiquesbuiltdaily.com/
