Shopsmith Bandsaw for Metal Question
Tom MacGregor
>I make my own jigs, fixtures & simple equipment and find myself cutting metal more often all the time. I have lots of small vintage belt-drive woodworking machines that work well if you take your time & don't push them too hard. I was thinking of using a Shopsmith bandsaw for aluminum & mild steel up to 1/4" by reducing the speed & using a proper blade. They can be found far cheaper than a 14" vertical saw and appear sturdier that the average small bench size saws (Sears, etc.) Avg. $200 to $225 on ebay. Any opinions or alternatives out there?
Re: Shopsmith Bandsaw for Metal Question
Jerry Gibbs
>I'm not familiar with the shopsmith band saw. Does it have its own power source? If you have to add a motor and speed reduction, I'm not sure of the economy. Jerry Gibbs
Horizontal/Vertical bandsaw
Virgil Johnson
>Take a look at a Jet 4 to 5 inch combo vertical horizontal bandsaw. They run about 350.00 delivered and offer a lot of bang for not much buck.
Gary Camp, Bend, Oregon
>At work I cut Aluminum all the time on an old Makita 10" mitersaw or my 10" table saw using a 60 tooth Woodworker II, I routinley cut up to 1/4", ocassionaly I will cut brass also, same saw same blade. Of course I wouldn't even try mild steel.
glc
I have spare motors & etc.
Tom MacGregor
Re: Horizontal/Vertical bandsaw
>The small horizontal bandsaw from Enco is about $200 and does a wonderful job. I got a copy of one at a yard sale. I highly recommend it.
cutting metal
>As others mentioned, take a look at a horizontal metal-cutting bandsaw. They have some real advantages for metal, especially steel.
A very important thing is the blade is twisted to get the back side out of the way. Without this, it's almost impossible to cut off a piece longer than the 14" capacity of a standard bandsaw. (Remember that steel stock normally comes in 20' lengths.)
Proper bimetal blades that will hold up to steel are readily available and the saw is built around them. The speed is already perfect for steel. Some come with a lubrication device but it's easy to add a drip where it's needed - without lubrication a blade may not last long. Some have auto-feed features letting you come back in a 1/2 hour when the cut is done. There is a built-in clamp to hold the work, including heavy round stock. The pivot keeps the cut straight across, which is what you mostly want, letting you control the feed for a very slow cut which is needed for heavier steel. You can easily cut things like 6" schedule 40 steel tubing. Try pushing even a long 1" round steel rod through a vertical bandsaw slowly while keeping the cut straight, especially if it's round - a straight cut means far less cleanup later.
They are not much use for making curved cuts or even straight cuts in sheet stock.
Another option is a portable metal-cutting bandsaw, a "portaband". I use a Milwaukee, usually with a 10-14 TPI blade and it is wonderful. I carry it to my shed with long stock instead of carrying the 20' pieces to the shop just to cut off 6". Great for cutting up steel shipping pallets that are sometimes available for free from the big equipment dealers, or trimming rebar or fence posts. Easy to handle cutting even very short pieces held in a bench vice. Mine is variable speed.
Another option is a metal-cutting blade in a reciprocating saw. I use the Milwaulkee bimetal blades called "The Torch" in a cordless Dewalt saw. It's amazing how thick steel this will cut with ease. This is good for cutting sheet steel, even relatively thick stuff.
The methods I use the least are the abrasive cutoff saw and the acetylene torch. Both are dirty and throw a lot of fire and sparks. You can't use one in the wood shop as you could a bimetal blades. The torch is invaluable for thick plate and rough work but it sure leaves a ragged edge. I once cut a small anvil out of a piece of railroad rail and what a mess!
