Re: Upside down paint storage
Alan in Little Washington (NC)
>Poly can be tough to keep- it starts to kick off in the presence of air and moisture (just like poly glue).
Not to steal the thread, but I was thinking, what about putting poly (and other finishes for matter) in a container similar to the new style baby bottles, but bigger- essentially a plastic liner inside a vented shell. As the baby drinks, the bag collapses- no take-up air gets into the bottle or the baby.
I would think paint would last a lot longer in a container like that, it would reduce waste, reduce the amount of air in the paint, reduce the loss of driers, be neater, cleaner, etc., etc.
It would require some other type of mixing since you couldn't stir it. You could mount a couple of containers, all having stop cocks on the bottom, in a vertically rotating rack. Each container would have a little ball weight in it that would fall (settle) from the bottom to the top to the bottom as the rack slowly rotates, stirring the finish. 10 min. before you are ready to paint, you turn on the motor that rotates the rack. When you are ready, turn off the motor and decant the amount of finish you need into your spray gun cup or into an open container if you will be using a brush.
What do you think? Should I call my patent attorney?
