Flat Polyurethane Spray Finish
Tomm
>Minwax does not make a clear flat oil based polyurethane finish in spray can form. Are any of the other companies making a flat polyurethane in spray cans? Thanks for your help.
Re: Flat Polyurethane Spray Finish
John E in SC
>When you say "flat", are you meaning "satin"? Don't think there is such a thing as "flat" poly. At least I've never seen such. I think minwax makes a satin rattle can poly, but if you can find it, you can use semi-gloss, then when dry go over it with 0000 steel wool to get the sheen you want.
John
Yep, Got a rattle-can of Minwax Satin in hand.
Scott in Montana
Karen
>Minwax, Rustoleum, Deft, Cabot -- they all make a satin poly in a spray can. I'm sure there are others but that's what's available in my area.
As for the "clear" part, I don't think I've ever seen a "clear" polyurethane. All I've ever seen or used has an amber tone.
