REAL MILK PAINT
OT - Critters in the overhead update - guilt
>I really feel guilty. I cut an access through my porch eaves. I put in a Havahart trap. It was too large to catch the critter and it got through the bars. I put up a mouse trap. It was too small to catch the critter. I used a glue trap. Sigh.
It was a small southern flying squirrel. About gerbil or hamster size. It probably got into the attic through the ridge vent and then down between the floors by following the trusses down. It was very cute. Now I feel like scum.
So - does anyone have any recommendations? I was thinking of the hardware cloth - but that means having to cut a hole and making an access port into the attic apace. I now have access to the eaves space so I could put some repellent up there.
TIA
Re: OT - Critters in the overhead update - guilt
Bill Houghton, getting sunny in Sebastopol, CA
>I'm not sure if there are hantavirus issues with squirrels as there are with mice - it may be cute, but it may not be good for you to have it in the house.
In responses to your previous post, someone mentioned mothballs; they do work really well, and, if you've got enough access to be able to toss them around, you may not have to cut a full body access hole.
Our bathtub was installed by someone who just cut a huge hole in the floorboards for the drain line, and some years back, the mice were setting up nests at the back inside corner. It was a little unsettling, taking a bath while listening to them. I was able to open up a little hole to reach in, and tossed most of the box in; they left.
albertabob
>Can you foam in the hole?
We use wire window screen and foam up here.
Bob
>Don't feel guilty. Although not often seen (mostly nocturnal, I understand) and small and cute compared to the normal-sized tree rat, flying squirrels can be incredibly destructive in a house and destroy wiring, insulation, etc. They can get through smaller openings that the larger tree squirrel. There have been plenty of house fires caused by these little darlings.
I read one article that speculated that a more perfect pest could not be designed - chew up your place, keep you awake at night. One homeowner caught eight in his attic, another, five. Seems like rat traps bated with peanut butter is the choice method of control.
Jesper, Denmark
Re: forget the hardware cloth....
Jesper, Denmark
>Forget the hardware cloth. I tried with red squirrels in NH. The little Sh**s just chewed in around it. The harware cloth was nice for them to hang onto while chewing next to it.
Nothing seemed to work, but 33 died at the help of an BB gun the first year. The second winter only 22!
One of these days, the ceiling will collapse from the tons of nut hidden in the attic.
With Bacon
Stuart Johnson
>Squirrel with Bacon
2-3 squirrels, cut into pieces
3-4 cups wild rice, cooked
5 ribs celery, chopped
10-15 pieces of bacon
5 carrots, sliced lengthwise
2 TB butter or margarine
salt
dill
garlic powder
parsley
Sprinkle squirrel pieces with salt, parsley, dill and garlic powder.
Wrap each with a piece of bacon. Use butter to grease shallow baking
dish. Spread rice in bottom of dish and arrange carrots and celery
on top. Place squirrel pieces on top of veggies and bake at 325 F for
2 - 3 hours.
>For several days we would come home from work and find things either re-arranged or something knocked over. Having been robbed a few times we were really leary of what was happening.
Then we were watching TV one evening and a baby squirrel just walked across the floor. My dumb dog who will chase a squirrel half way up a tree, just stood there and watched. I put some heavy gloves on and caught it and took it outside. It would run about 7 feet up a tree and then jump and glide toward the next tree. It was really cool.
Not a baby squirrel, John.
>That sounds just like what I have - they are southern flying squirrels.
Thanks all, I'll try the moth balls.
>I can either place them near the access in the eaves or I can go up through the soffits.
Re: Thanks all, I'll try the moth balls.
DP
>Mothballs have worked for me when I had a problem similar to the one you describe. But do NOT scatter them around. You will regret it. My wife made the mistake of doing that once in our attic and as the weather warmed up the odor drove us out of the house until we could retrieve them. (It's no fun digging through insulation trying to find mothballs. DAMHIKT) Rather put them in a loose weave cloth or a mesh bag. It will work just as well and you will be able to get rid of them when your problem is resolved.
A question about moth balls
Gary Camp, Bend, Oregon
>Do you folks think moth balls would work on Packrats? They are in the insulation in my pole barn. I will probably resort to traps.
glc
Re: A question about moth balls
>I think they would repel any kind of rodent. I'd probably use both kinds:
The two kinds of moth repellents I know of are the moth balls (naphthalene) and moth crystals (para-dichlorobenzene). I don't know about the relative toxicity, but I understand they are both dangerous for kids or pets and I was told the p-DCB was less toxic. Naphthalene is highly flammable.
Beekeepers use only the para-dichlorobenzene to keep wax moths from destroying boxes full empty honeycomb stored for the next season. I've been told the crystals is less toxic and will not build up in the wax nor will it kill bees. We were told to never use mothballs made from napthalene. I understand p-DCB is also used as restroom disinfectant. Note that neither of them last very long and must be replenished often in open spaces.
BTW, I read once that naphthalene has to be used in a sealed container to kill moth larvae inside (such as inside bags of clothes) but will repel insects and animals in more open spaces like attics. I use them under outbuildings to discourage skunks and groundhogs and in storage buildings where mice can get in.
Jesper, Denmark
Re: Mouthwatering.......
Jesper, Denmark
>Fortunately/unfortunately we do not have the squirrel problem here. They seem to stay where they belong - out in the woods. i do not really understand why, but maybe that there are not so many nut-bearing trees and very few wooden houses.
The recipe might work well with smller game birds like doves, quail and the small ducks.
You wonder why *LINK*
Dan Donaldson
>You have so much trouble keeping them out ;-)
(high speed connection required.)
Mouse maze
maybe if you tried this  *LINK*
Nah, probably too hard
