THE WOODRAT IS BACK!
sealing wood
sealing wood
sealing wood
Jeff Weaver
>A friend of mine had some storm damage this week that took out three large walnut trees. They are big trees, still on the ground and haven't been touched yet. He has offered me as much of the wood as I care to take. If I have to get something off the shelf at Lowe's or Home Depot to seal it, what's going to be my best bet? They're on the family farm in the next county, so I don't think they have to be moved right now. Since they haven't been cut, and still have the root ball on, how pressed for time are we?
As always, thanks for the help.
Jeff Weaver
Re: sealing wood
Re: sealing wood *LINK*
>Jeff,
You are not pressed for time. If the tree is not cut into pieces, it can sit for months this time of year with no degrade. In the summer, there is danger of insect damage but even then, it's usually confined to the bark and outer sapwood. I sawn walnut, y.poplar, oak, and pine logs that sat on the ground for a year or two and most of it was still fine. If the trunk is off the ground, it could probably sit until next spring before fungus started to grow. Sometimes a downed tree will keep enough roots in the ground to stay alive in which case you could come back 5 or 10 years later and the wood MIGHT still be OK.
As for sealer, a wax emulsion end-grain sealer is probably the easiest to apply, clean up, and most effective. Woodcraft sells it or you can order directly from UC Coatings in Cincinatti, OH. It's cheaper in quantity. If you have a sawmill nearby, they might fill your gallon jug for far less than the Woodcraft price. Other things people use: paint (can be effective or worthless depending), roofing tar (messy), melted paraffin,... If you want, check with the knowledgebase on Wood Web for a lot of information on alternative sealers, such as the kind of paint that will work the best.
If you plan on sawing pretty soon, you can get away without coating at all this time a year. In the summer, you can quickly lose 6" or so on the end of each log. For some people, even that doesn't matter much so they never seal.
JKJ in East TN
http://www.woodweb.com/cgi-bin/forums/sawdry.pl
Re: sealing wood
Re: sealing wood
>I use the white acrylic roof sealant on log ends. Trowel it on, and it cures to a flexible waterproof membrane.
Clint
Re: sealing wood
Thanks guys
Jeff Weaver
