Grinch Ate My SCMS
Grinch Ate My SCMS
Grinch Ate My SCMS
>Good Afternoon Friends,
It looks like my SCMS bit the dust. I bought it 12 years ago from a local trade school and, for $200, it gave fine, accurate service over that time. It was a 8 1/2inch version, and perfect for what I do. I checked with the Ryobi parts contractor by phone and learned they no longer provide replacement parts for the saw. I have one tool repair
shop locally which may have spare parts, and I am getting it over there on Monday. Repair costs are a factor in a tool that old. However, the cost of a new tool of the same capacity is steep, and so are the 10 inchers. Have been looking at ads for the 8 1/2" Hitachi and DeWalt sliders. Any ideas?
George
Re: Grinch Ate My SCMS
>I've had a Makita 10" SCMS for about 8 years that has been faithfully accurate for everything from deck building to picture framing. Great machine; job site portable; no problems. Also have the Hitachi 12" SCMS with laser and micro adjust. Bigger in every way. Quite unportable. Stays in shop on its own 8 foot bench. Current problem with the blade brake not wanting to work all the time.
Clint
>Colonel,
Obviously it is best to conserve available resources (i.e. money). I have seen some really nice CMS offered at HD, Lowes and Sears. I didn't check the sliders though. I'm trying to convince the playhouse to buy one - that's why I as checking. I'd check the sales though, I saw a Rigid 12" for ~$200.
Ray Newman
>I have a older Hitachi C10FS(??) & it has been very good. Settings are dead-nuts-on.
Have no idea as to how it would hold up on a job site as mine has never left the shop.
mdclor
>I have this same model and agree that it is totally accurate.
Sliders
>Hi Colonel,
Sorry to hear about the demise of your old slider. FWIW, I've been involved in a lot of SCMS tests over the years and it seems that Makita consistently does very well. The DeWalt 12" got excellent ratings, too, as did both Hitachis, but the latter were a bit less user-friendly to adjust. I read a review of 12" SCMS just the other day in Popular Woodworking. The eds really liked the new Milwaukee. They gave it their best-in-test award or whatever. Milwaukee's 10" saw used to be very good, too, as did Bosch's. I recall the Milwaukee having big, easy-to-read angle scales and good ergonomics.
I guess I'd most likely be looking at the Makita and Milwaukee 10" models if it were me. None of 'em are inexpensive. I've had my Makita 12" about 8 years now and it still works like a champ. I really like the new Festool, too, but it's out of my price range.
Good luck. Maybe Santa will be generous this year. :-)
Re: Grinch Ate My SCMS *LINK*
Carlos Clarke
>You might try:
http://www.reconditionedsales.com/
A number of us are using reconditioned Hitachi routers
from them in our CNC routers. Don't know about their
SCMS's.
Ralph Turney
>Sorry to hear about the demise of your saw. I had been debating whether or not to buy one, but since I still had an older 10" Delta MS that is VERY accurate and worked fine, I put it out of my mind...until I broke it, yes that's right, I broke it. The big piece that holds the motor to the table cracked...a piece of small stock popped up and there was a loud crack.
Anyway, I saw how expensive even the 10" SCMS's were and didn't even consider one, although I lusted after them. A couple of days later I went to a local lumber yard (Ganahl Lumber) and they had a Bosch 4410L SCMS that was sale priced at 399.99. I asked to make sure the price was correct and they told me that they thought that it was maybe being replaced with a newer model and that that was indeed the price. I bought it on the spot, new in the box. I haven't had the opportunity to use it that much, but so far it hasn't disappointed me at all. Looks to be well made and was the highest ranking 10" SCMS in the latest test I could find in Fine Woodworking. Everyone I had seen up until then over 500 dollars and even saw one that was 499 for a reconditioned model. Look around, you might get lucky.
Good luck,
Ralph
brakes
steve...brooklyn
>I recently had that problem with my old Makita 10" slider. I thought it might have been a problem with a part, but there are no actual brake parts. I researched it, and found that it's a problem with the brushes. I replaced mine, and now my SCMS stops on a dime, and gives me 9 cents change.
steve
steve...brooklyn
>George,
Have you checked with toolpartsdirect.com? They might have the part.
tool parts
Re: Sliders
Charlie Self
>I've had a Milwaukee 10" for a couple years now, and have nothing but praise for it. In the past, I tended to go for the bigger saws, but if I were doing it all today for the first time, I'd probably stick with the smallest blade diameter SCMS available. If for no other reason, they are easier for an aging body to tote around.
Thanks Steve
>But, no luck. I guess its way too old for them even to remember the model number. I'm giving the repair shop close by a chance on Monday to see if they have one to cannibalize. But I fully expect to have a new one on order by Monday evening.
George
