ot-computer dvd burner question
fred in ct
>i want to put a dvd burner in my 4 yr old dell, but i have a dumb question.is the burner just a burner? or can i play a dvd on it. also will it read a cd as i want to remove the cd unit because there isn't enough space for two.thanks fred.
Re: ot-computer dvd burner question
John McGaw
>A DVD burner will also read DVDs and burn/read CDs. If you check the published specs of the drive you intend to use there will invariably be a listing of what it works with and the most modern ones invariably work with all suitably-sized optical media. The exception will be support of Blu-Ray where things are still in a state of flux but given the exorbitant prices for the drives themselves and the media they use not too many people are adopting them yet.
Modern DVD drives also come with SATA interfaces as well as the old-school IDE so if you specifically need one or the other you will need to verify which the proposed drive supports. I'd guess that a four-year-old computer will be using an IDE interface for the CD drive so a DVD drive with that interface would be a one-for-one swap.
Jim Shaver - Oakville, Ont
>I put a Sony DVD burner drive in my Old Dell a few years ago. It played CD's and DVD's.
The Dell is now dead and gone (Thank God)... moved onto an IMac, a brillent system, so simple.
Take care,
Jim
fred in ct
>jim how do i tell if i have the ide or sata interface? the burner i'm looking at has sata. can this be adapted? thanks fred.
John McGaw
>If the existing drive has a 2" wide (usually gray) ribbon cable connecting it to the motherboard then it uses an IDE interface. If it has a narrow cable about the width of a pencil then it is SATA. The existing drive will definitely also have a power connector leading off to the system power supply (IDE will have a 4-conductor AMP connector and SATA will have a small wide many-pin connector). There may even be a skinny audio cable leading from the drive to the audio card or on-board audio system but these are pretty rare and are not really needed in a modern system.
You could use a SATA DVD drive if your motherboard has a spare SATA connector although some old BIOS arrangements may make this more difficult. It should also be possible to add a SATA controller card to the system but I don't recommend going to that extreme on what is basically an obsolete system. In any case using a replacement with the same interface as the old will be ever so much easier.
Re: ot-computer dvd burner question *LINK*
Jerry Nicholson
>Check the link for an adapter that will allow you to connect an SATA drive to an IDE connector. Also note that Newegg.com and others will sell you an IDE compatible DVD/CD burner for less than the cost of this adapter. For instance, check http://www.newegg.com/Product/Product.aspx?Item=N82E16827151175
Jerry
IDE to ATA adapter
Re: Dell model
Chuck W
>Fred,
What is the model number and year you purchased your dell computer. Chances are its has an IDE interface so you would need to order a DVD burner with the IDE interface.
Re: Dell model
fred in ct
dimension 2400 4-5 yrs old
fred in ct
Re: dimension 2400 4-5 yrs old *LINK*
John McGaw
>If Dell's online documentation is to be believed then the system in question has no SATA interfaces at all -- just two IDE drive connectors, each of which supports up to two drives each. Installing a DVD drive to replace the existing CD drive would be infinitely easier if a drive with an IDE interface is chosen. It would be a matter of disconnecting and removing the CD drive, determining how the CD drive jumpers are set, jumpering (master/slave) the replacement DVD drive to match, installing and connecting the new drive. Following that there would be the possibility of installing drivers. Then, if no software is already present, installing some program(s) capable of working with video. Sometimes the latter will come with the drive, sometimes not.
http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/techov.htm
Re: ImgBurn
Chuck W
>Fred,
In my opinion do not spend a lot of money, if any, on a burning program. I used to use Nero but found it is an overly complicated, extremely huge program to install and difficult to use. In other words not worth the money at all. Imgburn is a free program that can do a lot of what nero could and is very easy to use with great online help available.
Re: Dell model
Chuck W
>Fred,
a little more info as newegg have a special right now...
LG Black 22X DVD+R 8X DVD+RW 16X DVD+R DL 22X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache IDE 22X DVD�R DVD Burner with LightScribe - OEM
Special savings w/ Verbatim media combo, ends 12/31
Simple fix?
Bill Howatt
>If it were mine, I'd remove the CD drive, take it to a PC store and ask for a DVD burner. You can also likely get the latest OEM Nero Express burning CD that will support it for free. Nero Express is all most people will ever need if the Windows burning stuff is inadequate.
Bill
One more thing
Bill Howatt
>Since it is almost a certainty that the burner is IDE, if you aren't familiar with the Master, Slave, Cable Select IDE jumpers ask the guy at the store to set it the same as your CD drive.
Bill
Lee Gordon
Re: Simple fix?
Lee Gordon
>I've had good luck with the Geek Squad guys at Best Buy in West Hartford. You take your computer in, they tell you to go pick the DVD burner you want off the shelf, they install it, you pay and take your computer home. The drive to and from Granby will probably take longer than time you have to wait for them to install the new burner.
