shop heat
bk
>I just moved into my new shop, a 12x12 barn. It is insulated and has a cement floor. I am looking at the Eden Pure heater to keep myself warm,(upper Wisconsin). Has anyone had any experiance with this product in a similiar application?
shop heat
bk
Snake oil
>It's an electric resistance heater, and it doesn't matter if the element is NiChrome wire or some secret "quartz" gizmo. Their promo gives no information about the BTU output per Kilowatt. If you want a plugin heater, get a cheap one from any of the big box stores. It'll be just as efficient, and cost one tenth as much.
Clint
Check this out
>http://www.wcpo.com/mostpopular/story/EdenPure-Other-Space-Heaters-Tested/PdondT-tOkKTOuXc3gCxLw.cspx
Re: Check this out *LINK*
>Good article. It's nice to see facts instead of sales hype.
One small suggestion: instead of pasting your link into the box where you type a message, if you paste it into the "Optional Link URL" slot just below it will be clickable on WoodCentral and easier for people to access. Type in an "Optional Link Title" if desired for to make it look neater. Just a thought.
Re: shop heat
Jerry Gibbs
>Sorry about the cement floor. If it is not too late, I would lay down 3/4 sleepers and put 3/4 osb on top. I have a larger shop, but have a unit gas heater hanging from the ceiling and consider it my most important tool. I keep the shop at 34-50 and turn it up to 60 to work. The air heats almost instantly. My understanding is that upper Wisconsin is close to the artic circle. You will use the shop more if you can work without gloves. I don't think an electric resistant heater will work well. Jerry Gibbs
Re: shop heat
Paul Woolson
>I'm in lower Wisconsin but it was still 4 degrees this morning when I went to the shop. I purchased a Williams propane heater for my shop. One thing that is pretty critical is the humidity that I work in. This heater pulls the air from the outside for combustion, then exhausts to the outside as well. My humidity drops a bit but it's nothing that I can't control with my humidifier.
Might be worth looking into.
Re: Snake oil
Alex Grigoriev
>No matter what heater is, it's always 1000 BTU = 0.293 kW hour. Means 1 kW heater will produce 3413 BTU in an hour. Unless it's a heat pump.
Re: shop heat
bk
>This is why I came here with my question. Thank you all.....
