"Heat-Lock" Veneer Glue Experience?
Rick Haverstock
>I find myself needing to veneer some baltic birch ply with paper backed veneer and came across this glue in the Highland Hardware catalog. Seached the net and also came up with Joe Woodworker as a supplier. While they both loved the stuff, they both sell it and might be a little biased. Anyone have real world experience with this particular product? I've been very successful in the past using Elmer's yellow for iron-on work but would switch if consensus found this to be better. This is for flat panels captured in the traditional rail and stile grooves. Not looking to buy a veneer press or vacuum system for this one-time project. Thanks!!
Rick Haverstock
Re: "Heat-Lock" Veneer Glue Experience?
Herb Yost
>I'm a great fan of all Joe Woodworker's products, and have had great results using Heat-Lock, Titan, and the Cold Press glue. I especially like the Heat-Lock on tight interior curves (where an iron won't fit, and where the piece is too big or unwieldy to use a vac press)...used a heat gun and veneer hammer. I've made mistakes while veneering with the Heat-Lock and tried re-heating and pulling the veneer off so as to save the substrate...Hah!! Think again!!! Once on and cooled off, the veneer stays put!!!!
