ADVERTISE HERE - FREE TRIAL
Grooves in dovetails
Ed Beck
>I'm making a jewlery box and am using through dovetails for my joints. I need to cut a groove in the sides to receive the top and bottom pieces.
Cutting the groove in the tails is easy because the tails extend beyond the edge where the groove ends. I can just put the piece on my table saw and cut the grooves without worrying about the groove being seen.
I can't do that for the pins pieces though, since if I were to do so you'd see the groove, bad form.
I'm looking for advice on how to cut the grooves in the pin pieces? The grooves are 3/16" from the edges, 1/8" wide, and 1/8" deep. Any assistance is appreciated.
Re: Grooves in dovetails
Do you have a plunge router?
>That's how I would tackle it. I would clamp a ledger board on the piece (or build a jig if you are going to do a lot of them), chuck in an appropriate bit and cut away. I'd have pencil marks to show me where to stop.
If you don't have a plunge base for your router, I'd build a jig to secure the piece (and hold the router steady). I would then carefully lower the router onto the jig.
I wouldn't want to do it on a table saw. That would be a bit unsafe.
My $0.02.
Glue strip in exposed groove
Al Kapocius
Router table
Virgil
>Setup your router table with the desired bit and use two stops.
Bill H. in Jersey
>If you have a router table Lee Valley makes what they call "Box-Slotting bits" that I have had good luck with.
Alexander Grigoriev
>Put the box together without glue, tie it with sticky tape, and route the slot at once. After that, you'll just need to clean the corners.
Re: Do you have a plunge router?
Ed Beck
>Yes, I have a plunge router, it's one of the Freud 3 1/4 HP models that I have mounted under my table saw. Kinda a lot of caliber to shoot a squirrel.
Anyone know if I can get a plunge base for my Porter Cable 690 LR? I see it sold in a kit but I haven't seen it sold separately.
Agreed, dropping a piece of wood onto a table saw blade is not something I'll ever do. The tail pieces are such that I could run them through my saw since the groove is above the first tail. However if I went with a plunge router I'd use the same jig for everything.
Thanks for your help.
Re: Glue strip in exposed groove
Ed Beck
>I'm afraid that I don't follow what you mean.
Re: Happy Day! New Tool Time!
Dave Anderson (PacNW)
Re: Do you have a plunge router? *LINK*
Curly Smith
>"From the Manufacturer
This plunge router base is compatible with Porter-Cable routers 690, 9690, and 691. It adds plunging capability for safer, more convenient operation. A large locking lever and a depth stop with a six-position turret, makes setting router bits to the proper depth a breeze, and allows repeatable cutting depths. The fully enclosed springs ensure smooth operation through the 2-1/2-inch plunge range."
Porter-Cable 6931 Plunge Router Base for 693
Exactly How I Do It
Re: Router table
M. McNamee
>2nd the router table with stop blocks. Just be sure you do the correct side. Not that I would know anything about doing that.
Al Kapocius
>Cut the groove all the way across, including tail. Cut a thin strip to match groove thickness. Cut to whatever length required to close up the groove from being seen from the outside of the box. Glue the strip and trim flush.
With luck, should be almost invisible.
Al Kapocius
Sgian Dubh
>Here is a rather elegant solution. Cut a long part that will do for all the box sides. Run your groove near the top and bottom edge for your base and top. Cut this long stick into the lengths required for the two long sides and the two shorter sides. Mitre the ends where the two grooves are so that the width of the mitre fully encompasses the groove. Then make your through dovetails using the inside limits of you mitred edges as the beginning point for calculating the number of pins and tails.
Do a similar mitre where you want to split your lid off so that you don't have to cut either a tail or a pin in half. Slainte.
Ed Beck
>Perfect, thanks. My birthday is comming up and i dropped this into my wife's inbox.
Ed Beck
>That's simple enough even I might be able to pull it off.
Thanks,
Re: Router table
Ed Beck
>You might be familiar with my method.
1. Measure
2. Measure
3. Measure
4. Measure
5. Cut
6. Toss piece in scrap bin
7. Repeat 1 - 4, only this time measure the correct thing.
8. Fish last piece of of scrap bin, compare it to new cut lines.
9. Cut
10. Repeat as needed or out of wood.
Thanks for the advice.
