REAL MILK PAINT
OT-Fan to move heat room to room
Tom Dunlap
>The place that I'm renting has a wood stove in the kitchen/Dr which is about 15x30. This room gets warm and comfortable but I want to get some of the heat into the BR. The rooms are connected by a hallway that's about 12' long.
I have a large window fan that can sit on a stand about four feet off the ground. Maybe it should sit on the floor?
I'm wondering if I should put the fan in the:
BR doorway
kitchen doorway
Should the fan blow:
hot air into the BR
cold air from the BR into the kitchen
Chillin' in Dallas with my wood scraps!
Re: OT-Fan to move heat room to room
>Tom,
We have the same situation - toasty warm in the big room with the wood-burning stove and chilly in other rooms without moving some air around. I don't think it matters much where you place the fan, low or high, as long as you get some circulation. I'd probably try to place it so it wasn't blowing directly on or creating a draft where I was sleeping or sitting to read. I also think a fan blowing very slowly would work.
We use ceiling fans which seem to do the trick - one fan above the open stairs that lead upwards from the heated room, and one high near the beams in the bedroom (it's a timber frame house with sloped ceilings. Since the heat rises, this keeps nearly the whole house warm. (Except the garage where I have my lathe!)
The picture of the fan in the bedroom is from when we were renovating having just bought the place. (My wife would want me to explain that she has painted the wall and has curtains up now!)
John Veerkamp, Western Mo
>Tom,
We heat with wood also. JKJ's suggestion to use ceiling fans is what we do. In the winter reverse the fan so that it's pushing air up. It will push the warm air on the ceiling to the far ends . medium or low speed works fine for us.
Ebjuo the wood heat.
Al Stokka - Cambridge, Iowa
>Good day Tom,
I would put the fan on the floor in the bedroom doorway blowing s-l-o-wl-y toward the the kitchen.
Slow because you want to disturb the warm air flow near the ceiling as little as possible.
On the floor because that's where the cold air is and you want it out of the bedroom.
Cold air is harder to move than is warm air due to it's (the cold air's) greater density. So if you try to blow warm air into the bedroom, that warm air will have a tough time pushing out the cold air.
Also, you would probably feel a draft with the fan blowing into the bedroom, which would make it feel colder.
Good luck and try to stay warm,
Al
You can't do this......
Basil
>....in a rental house.
I saw how a fellow solved that problem once. He cut a circle (about 12") over each door and installed a small fan that moved the hot ceiling air from room to room. With all the inside doors open, the heat in the old house was fairly even.
Bill Howatt
>Have similar problem with lots of heat from a gas fireplace in the LR. Bedrooms are freezing. We have cathedral ceilings and so far I have not found a good solution. The ceiling fans are great for the rooms they are in but they don't move heat from room-to-room especially since the halls have "standard" ceilings which are lower. The furnace fan does nothing much because it is just grabbing the cold air from the floor and circulating it. There are higher returns but they are probably too small to be of much use.
I tried the fan in the bedroom doorway trick but it did very little.
Hope there are some bright solutions uncovered.
Bill
Jesper, Denmark
Re: The standard method would be.....
Jesper, Denmark
>Over here, a lot of people heat with wood stoves and have the same problem. What is usually done is to run a 6 inch duct from the hot to the cold room with a small fan - like a bathroom vent fan. Blow the air from the warm to the cold room.
You may not be able or willing to do this in a rental, but the owner should really appreciate you doing it.
Curly Smith
>You can:
- let your A/C system do the work if the air intake is closer to your fireplace than to the cold part of the house. Close all registers in the warm part of the house, turn the A/C to "fan only" and let the existing ducting move the air for you.
- use "door frame fans" (Home Depot sells them: ENTREEAIR Door Frame Fan as do other places)
- connect a register near the fireplace to a register in the cold part of the house with insulated flexible ducting, then install an "in duct" fan to move air through the duct from the warm room to the cold room. You can then control the fan with either a thermostat or manual switch.
- get an oil-filled heater for the bedroom to take the chill off
Thanks!
Tom Dunlap
>Al's answer is the avenue that I'm going to pursue first. While I was pondering all of the physics of cold dense air v. hot thin air I couldn't decide how to pump the heat. Makes a lot of sense!
Cutting in vents above the door may be possible. The house is likely to be demo'd when the property is developed...not too soon because of the real estate issues. There's a glut of houses in my area. I'll get hold of the landlord to see about ducting.
The door corner fan looks interesting...but costs so I'm less likely to do that.
I like this one...with a modification :)
I'd like to 'get a bloodfilled hottie for the bedroom to take the chill off" hehehhe :) And not of the feine [mine is too small] or the canine variety either!
Re: Thanks!
Gary Evans Tallassee, TN
>I don't know, Tom.
If you are looking for low cost solutions, the blood-filled hottie is probably not the best option. 8^]
Gary
Yeah, Fuel for those things cost a lot.
basil
>Diamonds, gold, furs, cars, etc......and then the heat at best is spotty and unreliable.
Re: You can't do this......
Charlie Self
>Some years ago, I was living in a rental farmhouse, large, two woodstoves. I bought two small fans (probably the case was 7" on each side of a triangle with an arch on the hypotenuse). The case contained a small, relatively slow turning fan. It is mounted in a doorway, up in a corner, out of the way, plugged in, and moves air nicely. Mine came with 15' or so cords, handy with two outlets per room (the wiring in this place was a caution, done long before building codes).
Heat upstairs was no problem, if the hall was warm, so I put one on the LR door to the hall, one on the LR door to the kitchen (the LR was actually the old dining room, and the real DR was my shop).
Worked great, but I really don't know if you can still find them, nor do I recall their name. Heat transfer fans or some such.
The things 20+ years can do to a memory!
The solution!
Tom Dunlap
>After reading Al's advice I slapped my head! Of course...'The world runs on hydraulics' is what Greg Crowley, the fluid power instructor at the tech college I attended would say.
I scavenged a multi-speed desktop fan and put it in the corner of the BR doorway. It works really well! The BR stays warm all night!
Re: using the central HVAC fan
Yonak
>Someone, one time, suggested reworking the return air ducting putting a return port in the ceiling right above the wood stove and using the fan in the HVAC unit to blow the air to the cold extremities, as Curly suggests. Every winter I think about trying this, but it would be a fair amount of work for a questionable solution. Has anyone heard of this being a good idea ?
>A friend built a house with an alcove for the stove. Had a return above the stove. It worked well distributing the heat but the unintended consequence was that it cooled the flue pipe and there was a build up of creosote and he had a flue fire. Very scary. Scared him so badly he stopped using the stove.
