Performax Sander questions
>I have a Performax 16/32 I bought used. I have a copy of the manuals, but not a good copy.
The tension rollers (That press the stock down onto the belt) were loose to the point they only had their own weight and could be lifted half and inch or more. The instruction say to loosed the bolts with the drum on the table/belt and raise the drum a turn and then tighten the bolts. I see bolts that are in the ends of the rolers, but they do not appear to have any adjustment in them and I don't see who I could loosen them. (No room for a wrench or socket) The other bolts I see are the ones that hold the bearing for the drum itself. Can't imagine how they could be the right ones.
There are Phillips Head screws in the tops of the levers that hold the rollers. They were loose to the point of falling out. I tightened them and the roles are now snug and difficult to lift.
Can somebody explain this better?
Re: Performax Sander questions
Dave Paine
>I have a Performax 16/32 which I purchased new. I will have the manual somewhere, but it was faster to look at the machine than find the manual.
Looking at my unit, these rollers have at best a weak spring at the end. It appears most of the action is good old gravity. The Philips head screws look like stop adjustments to get the roller to be parallel with the drum. Normally the drum is then adjusted to be parallel with the bed.
I hope this helps. I have used this machine many times. I do not consider the rollers to aid in alignment of the wood being sanded, which is different than the rollers in my planer.
