On the off chance that this might just work out, I've found a 1950s Atlas shaper, model 3500 (see link). It has a (non-original but working) 3/4hp craftsman induction motor, 1/2 or 3/4 inch collet, no fence, and looks in decent shape if you look beyond the aesthetics.
I'm looking to move to a spindle shaper. How can I not get this for $100??
>Id buy it in a minute for $100. even if the motor didnt work you never knkow when you would need something like this. I have a smaller table top shaper and I use it all thetime instead of fooling with a router table and it works good. Jared
>... some of the things you would want a spindle shaper for. This is a benchtop shaper running at a fixed speed of 8250 rpm. (You can put a drum sander head in there if you're willing to change the motor pulley to slow the spindle down, and even then it will be running way too fast to be useful as a sander. It takes only 1/2" bore cutters, of which there are plenty to be had for a song -- notably a lot of old Sears and Shopsmith cutters -- but it doesn't have the power or capacity to do things like stick and cope larger doors, raise panels and pattern-shape thicker lumber. Also, I think you might want to replace the bearings with sealed ones.
Call me biased, but these small shapers are more like underpowered router tables than serious shapers. Routers and router tables made these small shapers virtually extinct about 25 years ago. If you're thinking of mainly using it for small jobs or as a dedicated rabbeting or beading tool, I guess you can't go wrong for $100. But keep your shaper savings account open until you can afford a bigger machine, preferably two-speed, reversing, with at least a 3/4" spindle that will accommodate 3" or 4" high cutters. If you ever contemplate making front doors or bar rails or large moldings, save up for an even bigger one, preferably with a power feeder.
>Can you spare another 2�? I'm considering a used Jet JWS-18, much newer and little used, but with a 1 hp motor. What I want to do is cut a bunch of tongue and grooves for workshop flooring, from either poplar or cherry or oak (all readily available). I have no plans/hopes/desires to do raised panels.
However, I read someone elsewhere saying a shaper needs at least 3hp to be worth the floor space.
Is this the wrong machine for that flooring job? Just hire it out?
Keith Newton------WebKitFormBoundaryV6MZb+tiOpocz6
Guest
Re: A penny for your thoughts
>I wouldn't give $10 for the Atlas boat anchor which the first poster ask about. I had one of those back about 30 years ago. and it was not worth having.
John, I tend to fall into the 3 hp minimum camp also. However T & G doesn't require a lot of power either. On the other hand, using a big router with the higher RPMs will allow a faster feed rate, and better cut.
If you are going to run enough to do floors, then you are talking volume. I hope you have a power feeder or two. When I have long running jobs like that, I usually try to have two machines running at once, to cut the time in half.
>I'll just have one floor, in the "wood" side of my shop - about 20'x40'. I don't care so much about the time involved, I just want to avoid trying to do it with the wrong tool. I wondered if doing that much flooring would burn up or wear out a router.
>My Dad had this unit in his shop and I now have it. I use it all the time for small work. I installed a drum reversing switch and have a 3/4HP motor. It is the best little shaper I have seen. Mine has original fence and is installed on a steel tube and heavy base for rigidity. I would like to know how to get a copy of the OE manual??
