THE WOODRAT IS BACK!
Refinishing a veneered chest.
Gary Evans Tallassee, TN
>Hi all,
I am going to refinish a cedar chest as a Christmas present for the mother of a friend. The chest appears to have a veneered exterior. Any suggestions on how to get the old finish off without loosening the veneer?
Thanks,
Gary
Re: Refinishing a veneered chest.
Decision tree
>Gary, I would first try to determine what kind of shape the veneer is in. If it seems pretty solid, you could try using a gentle stripper. Swing Paints (Circa 1850 Products - check the Marketplace page) makes some good ones. Before that, though, try some lacquer thinner or solvent alcohol in an inconspicuous spot. A lot of those cedar chests were finished with shellac, so you might be able to clean it off just with the thinner. If the veneer appears to have a lot of fine checks in it, you might want to avoid adding any liquid to it. In that case, a card scraper and a sanding block might be the best recourse.
David Yoho
>Gary, some years ago I took on refinishing a very old oak dresser. I knew the top was veneered but I didn't give a thought to the drawer fronts. This dresser had a dreadful black paint on it and the toughest-to-remove red primer I've run across. Not being able to actually see any of the wood under that paint, and from looking at the rough solid oak frames inside, I went ahead full speed with my normal stripping process. It wasn't until after I'd rinsed away all the stripper that I realized the drawer fronts were veneered with a bookmatched quarter sawn white oak veneer. (Great time to figure that out!!)
Long story short, only one drawer had a problem with the veneer loosening and curling away from the solid oak front. It took some careful work but I re-attached it like new. Not being careful from the start, I applied stripper twice and rinsed with a hose each time. They got pretty wet for veneer. Maybe I just got lucky!
I think I'd try an approach like Ellis mentioned. If your finish is shellac, alcohol evaporates fast so no problem there keeping things wet too long. Another thing that will dissolve old shellac, if you can stand it, is household ammonia and a white Scotch Brite pad. The ammonia may also pull some of the color from the wood too. At least it did on an old solid cedar chest my wife got that was her mother's.
David
Re: Decision tree
>Hi Ellis,
I took my first good look at the chest today. The veneer does appear to be in pretty good shape everywhere on the chest. Unfortunately there are a couple of places on the top where someone has dabbed on some new, darker stain so now I'm concerned about evening out the color as well as getting the old stain off.
Believe me, all suggestions are appreciated.
Gary
I suggest...
>... that you remove the finish first, then decide on what if anything to do about the stain repairs. A few swats with a scraper should take care of the stain in any case.
