Finishing Cypress
Finishing Cypress
Finishing Cypress
Bear
>I'am making a bench for a shower room and want some ideas on a good finsh for this bench sense it well be located in a wet area.
Re: Finishing Cypress
What I've done...
>... in the past runs the gamut from no finish at all (think redwood sauna interiors) to a good soaking in pure tung oil (which soaks in and looks dull but protects) to spar varnish (which forms a film on the surface that must be maintained). Nowadays, I think I would put some deck finish on it. Cabot's Australian Timber Oil is a linseed oil based finish that works a lot like my old tung oil. You need to wipe off any excess, though, or it will not dry.
My 2¢,
Bill White
>WHAT DO YA MEAN BY "SHOWER ROOM"? In a dressing area, or actually in a spray environment?
Personally, I wouldn't want my butt on an oil finish in a dressing area or a shower stall. Of course I can fall off the floor too!
Leave it natural is my vote (if get one).
Bill
Why bother, Cypress loves water.
Art Silva
If you feel you must, Sikkens Cetol is best.
Art Silva
Epoxy then Varnish
Joe in Tallahassee FLA
>You may want to consider a clear epoxy, like West System, with a couple top coats of varnish. I used this on my Cypress boat console a couple years ago and it is holding up very well. I wash it down with a hose after each trip.
The top coat I used is a two-part linear acrylic urethane with the maximum amount of UV blocker. The top coat is primarily to block the UV which will harm epoxy. It doesn't sound like there will be much UV hitting it in your application so you may evaluate the need for, or type of top coat needed.
Jim Dillon
>Bear,
In my limited experience with cypress building two Adirondack chairs, a garden bench, and an umbrella table, I've found cypress to be a very forgiving wood wrt finish. Based on seeing a lot of unfinished, though weathered, old cypress covered houses in Lousiana (where I lived for awhile and purchased my cypress), I would come down on the side of no finish. Cypress weathers to a nice gray and you don't have to worry about refinishing. My next choice would be a nonfilm finish like the Cabot brand Ellis mentioned, or perhaps Penofin, although I have no direct experience with either but have read good reviews of both. If you want a film forming finish, I agree with Art regarding the Sikkens brand. While I used a Sikkens cedar stain on my outdoor furniture, I believe they make a clear finish which should work well as UV protection would not be needed in your case. An excellent source of a variety of quality marine finishes is Jamestown Distribtors. Just my thoughts.
Jim
Please read this warning first
Michael Dresdner
>Many exterior deck finishes contain mildewcide and fungicide. I would not use them on interior furniture next to skin if I could avoid it. They are, after all, poisons, just like weed killer, and I doubt you want that in the sauna or shower. Simple oils or interior oil based film finishes are fine, but for the record, I agree with the majority on this one -- I would leave it unfinished.
Thanks, Mike
>It never occurred to me that deck finishes have toxic chemicals in them. So much for speculation. Thanks for the warning.
