Have a question? Ask Woody!
Anybody use a propane radiant heater?
Tim Greif - West of Chicago
>I'm giving my son a Hamilton Home Products gas unit heater for his garage shop for christmas, but the install won't happen until spring due to the need to cut open the wall for the horizontal vent. In the meantime, I was wondering if he could use one of those propane radiant heaters that screw onto the top of a 20 lb propane tank for the times he needs heat to work (not woodworking, just car stuff).
I already know about the moisture addition caused by this and kerosene type heaters. He already has s spare 20 lb tank and these small units only cost about $30-40. Any downside for occasional use?
Re: Anybody use a propane radiant heater?
>I have or at least had one and used it occasionally to knock the chill off my one car garage/shop. On the coldest days I would run it for five or ten minutes and then turn on a little electric heater. The only problem I ever had with it was It got shifted under my air hose that was hanging from an overhead hook and the little curlycue hose overheated and got an aneurysm and burst. $8 down the drain.
John E in SC
>I've got one of those for my unheated basement shop, and I think it works well. If it's really cold and your garage isn't insulated, it may not be enough to really warm things up, but in my basement, I can usually run it for about 10 minutes, and then it gets warm enough for me to cut it off. They're cheap, easy to use, and don't really cause any significant odor.
John
>Look at the thread "heating a workshop" from a few days ago. Portable radiant propane heaters are discussed. I have one and use it sometimes, kerosene sometimes.
Re: propane radiant heater - no issues
North of the Border
>that I'm aware of -other than the standard safety things like no open fire near inflammable substance, don't leave the shop with the heater being on. If you're worried, give him one more gift along if he doesn't have one already: a fire extinguisher. I have one standby but have used my heater without any problem so far. I start with the high setting for about 10 minutes (200 sq ft garage) and then set it to mid or low.
>I used one in my garage workshop for about ten years and would run it continuously for five or six hours at a time. It does crank out the heat. It worked best with an oscellating fan 18 inches behind the reflector to distribute the warmth.
Clint
One more gift to give
Lee Schierer - McKean, PA
>All burners of that type emit carbon dioxide and possibly carbon monoxide. Give him a CO detector to keep him safe. CO and CO2 can build up without you even noticing it and knock you out. Symptoms are fatigue and headaches after being in the area for a while.
Lee
Hmmmm ---- a question about that fan
>I thought all these radiant heaters put out infrared heat. They heat objects, not the air. How does a fan help in this regard?
GalenV
>I would worry about doing car repair and gas fumes with short bottle setting on the floor. That is just one of the many warnings on the units. They used natural gas units in our fab shop but high in the air and most of the time bay doors would be open enough you froze to death anyway, but never overcome by fumes.
I guess if you took the manual warning below you would use it outside only to warm your buns. Who reads the manual anyway?
For outdoor use only. Area must be well ventilated. Provide minimum openings of 1 sq ft (0.093 m�) near the floor and 1 sq ft.
(0.093 m�) near the ceiling. Do not use inside house, camper, tent, vehicle, or any type of unvented or enclosed area.
>Tim I use one all the time. I'm heating a 2 car garage and it really isn't enough for that but it does warm it up quite a bit. On really cold days I have trouble getting the shop up to 50 degrees but then it wasn't designed to heat an area this large and my shop isn't insulated as well as I would like.
I heat with Kerosene and this propane stove and I don't notice any moisture increase but then I don't have a way to measure it. It hasn't affected my tools or processes.
I do run it all night long to heat the shop up for the next day. maybe that's not the smartest thing but it works for me. I keep anything flammable at least 3 feet away from it. If the flame goes out mine shuts off.
As far as CO2. I guess my shop leaks too much. I've run this thing a lot and no problems. That doesn't mean you should not be cautious.
I Use a Ventless Propane Wall Unit
Barbara Gill, Remlik VA
>It does a great job of heating my little enclosed turning area. All ventless propane heaters have a O2 sensor which will shut the unit off if the O2 level drops. I do not use the heater unless I am in the shop.
The reflecter gets mighty hot
Re: One more gift to give - good idea
North of the Border
>I was about to say in my last post that good ventilation should be maintained when the heater is in use.
I can vouch for that...
John E in SC
>just barely bumped mine a couple weeks ago when I went to turn it off, and burned the you-know-what out of my hand!
