Question for doll house builders
Ed Mulligan, Cape Cod
>Hi all,
I�m looking for brain dumps on doll house construction.
To keep close to 1/12 scale I�ll probably use nominal 1/4" plywood for the exterior walls. How might these walls be joined? I�m considering using a butt joint with construction adhesive but would appreciate hearing alternatives.
Another thought is to use foam board aka foam core like architects use for their models. Anybody tried this? I�d probably use hot melt glue to join it. Too flimsy?
I�m also interested in strategies for knock-down construction in case my client wants to go that way.
Thanks!
Ed
Re: Question for doll house builders
Tony - Memphis
>I built a kit many years ago. The corners were made using wide fingers or tabs. Worked pretty well. The floors were tabbed into the sides and front thereby stiffening the whole structure pretty well. I only used the kit to start with. I added lots of aftermarket stuff. I was living in an apt and had no tools, so I was limited. Turned out reasonably well though. The local shop used 3/8" baltic birch for their custom houses. If you did that, you could make fingers on the top and bottom and pin them to make it "break down." Mine rode in a crate in the back of my S10 to NC. Long ride!
Tony
Winnemucca Lynn
>Wood Magazine has plans for a couple of doll houses, one of which uses tabs and breaks down into a size that can be carried away in a case. I just saw the plans offered for sale on their site. (Wood Store or something like that.) No affiliation, just someone who wishes he had time to make one or two of these.
Lynn
Steven Antonucci
depends upon the application...
Steve Antonucci
>I'd think 1/4" plywood wouldn't stand up to much use if you were making it for a little girl? I'd suggest more like 1/2". In my experience (4 houses), if they are only "lookers"-1/4" might be fine.
Steve
steve mackay
>I used 3/8 birch ply for everything. Takes paint better and fairly kid proof. They'll bust up 1/4 pretty quickly. Yellow glue to joint everything and hide small, plain "L" brackets in all the corners. When they fall on it OR they want to move, remove the brackets and the joints will just "snap" apart. As much as possible gets built as sub-assemblies, ie : before you put the walls together finnish-paint, "hang pictures", install window trim & curtains. Always easier when the work piece is laying flat. Good quality terry towels for carpet and lawn. Use rubber cement so it can be replaced easily when it gets dusty. Good luck. Fun project. Turn your imagination loose !
George Koch
>Ed, 3/8" plywood would be closer to the true wall thickness for a 1/12 scale model (1"=1') George
Very helpful. Thanks!
Some inspiration
>Ed, on my way home from the Berea conference a few weeks ago, I stopped at Pleasant Hill Shaker Village and took a quick tour. I hadn't been there in 30 years and I had forgotten the amazing doll house in the basement of the main building. Here's a shot of it. According to the tourguide, it took them 20 years to complete. A gift to be complicated. :-)
Amazing!
