>I have made a cutting board out of mixed hardwoods. Glued up strips and then cross ripped it and turned them so that it is end grain. Something of a brick pattern. Sanded it int he Performax and a bit with a ROS, but there are a few slight scratches left. The question is, Is there any point in sanding it to perfection? Isn't it going to get cut and hacked anyway? How far do you go with this?
>Good morning, Barry. Every project has a designer and a customer. If you are the customer, you get to decide whether your "slight scratches" matter enough to justify the additional time and effort. Personally, I tend to regard cutting boards as utilitarian objects, so they don't get as much sanding and finishing as finer pieces.
>Barry, I just finished and delivered four maple cutting boards. They were not end grain cutting boards but the strips were face glued, which allowed the cutting surfaces to be edge grain. I mixed in three cherry strips for each board to add a little something to the look. Each board measured 24" by 30".
I'm in agreement with Ellis as to these sorts of things being utilitarian. After final glue-up of the sub sections for each board, I smoothed any uneven joints with a cabinet scraper and sanded with a ROS to 100-grit. I wasn't too concerned with scratches, although none were visible, because it I knew it wouldn't be long before these boards are "scratched" from all the constant use they will see.
>I am not sure what your scratches look like, but I don't leave anything that a casual observer would see as a scratch, nor does there seem to be any need to since you are power sanding.
End grain is resistant to sanding but it takes a wonderful polish. I usually plane a cutting board, then belt sand at about 100 grit which leaves a nice burnished polish. I might continue to sand more to get the burnish, if needed, but not beyond about 120 grit. Then a coat of oil and the end grain glows.
>Let me preface this with I've never done an end grain cutting board.
I have used water based stains on various pieces though. If I didn't do a water wipe followed by sanding, I usually got a lot of "fuzz" all over the piece. I admit I didn't keep track of what was end grain and what was side grain. I'll also admit that the pieces were usually curved, so that (except in the very back) there may have been a mixed grain component.
